JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Manifold lambda
Manifold lambda
Manifold lambda
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:04 AM
What I've done is got hold of a stainless manifold and fitted then gone to put sensors back in and the rear one there is not enough room to get it in not without some major fabrication so I blanked it and wired the rear wiring so all comes off front sensor. Fine for a while then light came on if I unplug and reset codes with obd it shows all fine and sensors working fine but if I turn off and start again they dnt work! Anyone got any ideas what to do????
Jimbob-T-Lex
10-07-2019, 07:04 AM #1
10-07-2019, 07:07 AM
have you got a pic of the offending location
you should be able to get the sensor back in ?
what about fitting it then fitting the manifold ?
10-07-2019, 07:07 AM #2
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:17 AM
I tried all mate there is no room just hits the bulk head basically a badly designed manifold unless I get the sensor fixing moved or reshape my bulk head then Im gonna have to wire rear into the front just weird how it works but if I turn off and start her up again it stops and I get engine check light
Jimbob-T-Lex
10-07-2019, 07:17 AM #3
10-07-2019, 07:19 AM
something dont sound right as when i had my manifold i wired both sensors into one input and it worked fine it have you tried plugging into the other sensor location ?
I.e not in bank 2 but in bank 1 ?
10-07-2019, 07:19 AM #4
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:23 AM
What I've done is I've bank 1 sensor fitted and plugged in and works fine then I wired from bank 1 sensor into where the bank 2 sensor connects, do you know what the black wires are I could have them wrong way round as there is two
Jimbob-T-Lex
10-07-2019, 07:23 AM #5
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:30 AM
[Image: 004-8.jpg]
[Image: 005-6.jpg]
Jimbob-T-Lex
10-07-2019, 07:30 AM #6
[Image: 004-8.jpg]
[Image: 005-6.jpg]
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:33 AM
Just googled and the black cables are heaters do i need to connect them as no sensor is actually there
Jimbob-T-Lex
10-07-2019, 07:33 AM #7
10-07-2019, 07:39 AM
when i piggy back mine i connected all of the wires in....
10-07-2019, 07:39 AM #8
Jimbob-T-Lex
Moderator
1,674
10-07-2019, 07:43 AM
i just cant see where the problem is it should work
Jimbob-T-Lex
10-07-2019, 07:43 AM #9
10-07-2019, 07:44 AM
What is the fault code the ecu is showing ?
10-07-2019, 07:44 AM #10
Views 1,020
25-02-2021, 11:21 AM
Last Post by S
Views 645
05-07-2019, 06:05 PM
Last Post by Kerja
Views 630
29-05-2019, 04:01 PM
Views 1,298
17-05-2019, 12:49 PM
Last Post by Jimbob-T-Lex
Views 1,434
15-05-2019, 09:30 AM
Views 1,315
24-11-2017, 04:10 PM
Last Post by jay_russell
Views 672
12-10-2017, 07:14 PM
Last Post by mikeyb2009
