JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Key Casing Broke!
Key Casing Broke!
Key Casing Broke!
Pages (3): 1 2 3 Next
Dinho
09-05-2020, 05:41 PM
As in title I have broken my key casing for my IS200 keys, to the point where when I start the car up, the casing falls apart as im turning it!
Ive seen some flip design cases on ebay, and some original look alikes, what do people recommend I get?
And whats the easiest.
Thanks Smile
Dinho
09-05-2020, 05:41 PM #1
Thanks Smile
09-05-2020, 06:44 PM
It's your preference mate, I tried the flip key, hated it, but then again I've got rid of keys altogether lol
09-05-2020, 06:44 PM #2
jomo
09-05-2020, 07:49 PM
I have a flip style key and love it, not the best made flip key compered to say a VW or Audi one, but iv had it for 2-3 years now and its going strong.
[Image: is200%20catoon.jpg] [Image: 104113415648fa201e2ecb5.gif] [Image: 91-bluescreen.gif]
jomo
09-05-2020, 07:49 PM #3
Dinho
09-05-2020, 08:01 PM
With the flip key, did the key need to be cut? And was it easy to transfer all the electronics?
Dinho
09-05-2020, 08:01 PM #4
09-05-2020, 08:09 PM
The electronics ares simple to move, but you'll have to check with key cutters if they can do it as they need a fine cutter.
09-05-2020, 08:09 PM #5
Dinho
09-05-2020, 08:21 PM
Ok thanks for the advice
Dinho
09-05-2020, 08:21 PM #6
10-05-2020, 03:35 AM
I would say if you can update the key to a flip style defo do that infact I may even look at it :lol: :thumbup:
10-05-2020, 03:35 AM #7
Matt_C
26-06-2020, 04:08 PM
I've just received a flip key (eBay) to replace one of the two broken keys that came with my car (the valet key is mint, but the other two are broken/cracking) and it's not a great quality item. Ok, it was only £7, but it needs a stronger spring to flip the key out properly, and it's a little bulky. But, I'm gonna see if I can get it cut and see how I live with it anyway. I've already transferred the button pack from one of the busted keys into it, just to check it all fits and is useable, so I also checked that it should work in regard to the transponder - as I'd read here and there that the transponder is too far away for the key to work. Used the now empty key and of course the engine only turned over and wouldn't start. So I tried again holding the flip key against the now empty key at about the position it would be if it was just the flip key and the engine started no problem. So by the looks of it, it will start the car. Just got to get the blade cut now
Question - the transponder in the button pack. I take it is powered by the battery in the key? When the battery gets low, will the signal strength of the transponder also get low, as in low enough that I won't be able to start the car? If so, is it easy to change the battery over or will it lose all it's programming?
Matt_C
26-06-2020, 04:08 PM #8
26-06-2020, 04:39 PM
As far as I know the transponder for the immobiliser isn't powered, only the remote is but someone please correct me if I'm wrong Smile
26-06-2020, 04:39 PM #9
26-06-2020, 06:53 PM
Correct the transponder is just a little "rock" in the corner of the fob.
26-06-2020, 06:53 PM #10
Replies 25
Views 2,445
19-03-2018, 10:52 AM
Last Post by is300_dino
