JapCarForum Cars, Cars, Cars! Project Cars Supercharged Lexus IS200 SE
Pages (132): Previous 190 91 92 93 94132 Next
16-11-2022, 08:56 AM
did he get his hands dirty lol
16-11-2022, 08:56 AM #911
jeorje_2000
23-11-2022, 11:21 AM
Lexuspat Well the last few days the charger has not felt as it should, so bonnet up and had a hunt, found an air leak between the outlet pipe and charger.
So last night the kit came out and a liquid gasket was put in place. All sorted and running sweet again.
And today i temporary fitted the boost gauge in the centre consol until i order a pillar mount
Hello,
what presure do you have with the standard pulley on the gauge?
jeorje_2000
23-11-2022, 11:21 AM #912
Hello,
jeorje_2000
23-11-2022, 11:28 AM
Lexuspat Its mounted on a silicone T pipe similar to what u would use for a BOV, but has a custom mount plate that reduces the diameter down to 25mm. Thats it really mate.
What is the actual diameter of the bypass valve?
jeorje_2000
23-11-2022, 11:28 AM #913
23-11-2022, 12:20 PM
Outlet side is 40mm
Sent from my K017 using Tapatalk
23-11-2022, 12:20 PM #914
Outlet side is 40mm
23-11-2022, 08:30 PM
By what it reads I produce between .4 and .5 of boost
23-11-2022, 08:30 PM #915
jeorje_2000
26-11-2022, 04:53 AM
Lexuspat By what it reads I produce between .4 and .5 of boost
with the stock pulley should be max 0,35, mine it is 0,35 and almost 0,4 after 160 km/h because a have kept the original cold air intake but the accelerations it is good View My Video
If you have 0,5 you should run even better you have a movie?
jeorje_2000
26-11-2022, 04:53 AM #916
27-11-2022, 04:16 PM
I don't have a good film but will try and get one done soon. I would say being realistic and the type of gauge I have 0.4 is where it is she pulls very well for a custom made kit
27-11-2022, 04:16 PM #917
29-11-2022, 06:10 AM
Finally ive managed to get hold of yellow vac lines so will start getting the bay looking a little nicer for show season
29-11-2022, 06:10 AM #918
29-11-2022, 11:53 AM
all the small bits Smile
29-11-2022, 11:53 AM #919
29-11-2022, 12:13 PM
That's it at JAE is only just finished it off so wasn't looking great. Hopefully when I finish it will look a lot nicer
29-11-2022, 12:13 PM #920
 7 Guest(s)
 7 Guest(s)
Views 13,460
Views 3,693
Views 20,502
Views 43,305
Views 127,497
Views 1,222
Views 3,386
Views 12,221
Views 6,156
Replies 76
Views 6,978
29-09-2024, 07:13 AM
Last Post by RichS11
