JapCarForum Cars, Cars, Cars! Project Cars My little project - IS200 Turbo
Pages (132): Previous 137 38 39 40 41132 Next
Phoenix
05-11-2017, 04:29 PM
5K on and their fine!!
Phoenix
05-11-2017, 04:29 PM #381
05-11-2017, 05:28 PM
ok, for those who don't want to read through the whole 42 pages, here's a quick summary of all the work that's being done on my car :
- Replace OEM rods and pistons with 1G-GTE rods and pistons (and any new shells etc as necessary)
- Replace OEM injectors with 550cc Power Enterprise injectors
- Fit SPC turbo manifold, Garrett GT2560R turbo and intercooler
- Replace OEM clutch and flywheel with Helix Stage 1 upgraded clutch and JUN lightweight flywheel
- Replace TTE springs and OEM shocks with BC Racing coilovers
- Fit GReddy e-Manage Ultimate and perform mapping
- Fit necessary piping for intercooler and downpipe
- Fit induction with Apexi cone filter
- Fit dump valve
- Replace IK20 spark plugs with IK22
- Change OEM oil filter and fill with fully synthetic Silkolene oil
- Replace OEM brake pads and discs with Black Diamond grooved and drilled discs plus Predator pads
- Replace OEM brake lines with Goodridge stainless brake lines and replace brake fluid with DOT 5.1
- Fit Innovate LC-1 wideband lambda sensor and AFR gauge
- Fit Defi Advance CR boost and oil temp gauges, and control unit
05-11-2017, 05:28 PM #382
- Fit dump valve
05-11-2017, 05:40 PM
Marsdendean Have you been given a quote for separate items Steve, as i was looking at different brakes ie drilled and grooved and was trying to see how much more expensive they are compared to OEM and mintex pads
Not for the labour etc, no. But I have prices for all the parts that I've supplied myself (which is most of them), I'm keeping track of all of that in a spreadsheet.
I paid £81.18 for a full set of Predator pads (front and rear), and £443.01 for a full set of discs from Black Diamond (who make the Predator pads as well). I got them from Motorsport World.
05-11-2017, 05:40 PM #383
05-11-2017, 05:48 PM
Cheap discs are a false economy. Especially when you're talking about drilled ones - most of the ones on eBay for example are stock discs which have been drilled which weakens them and they crack up under hard breaking.
I've warped cheap rear discs on my car which doesn't have uprated brakes in any way shape or form! Think my discs were about £100 each.
05-11-2017, 05:48 PM #384
05-11-2017, 05:55 PM
Agreed, you need to be very careful about buying drilled discs, it's easy for anyone with a drill to put some holes in any old brake discs and sell them on eBay.
05-11-2017, 05:55 PM #385
05-11-2017, 06:00 PM
Marsdendean I meant compared to standard OEM ones.
I would never buy cheap disks from ebay, i might aswell get some OEM ones, a 6MM steal drill bit and a grinder and do the job myself!
How do you know the discs won't end up cracking because you've weakened them by drilling them ?
05-11-2017, 06:00 PM #386
05-11-2017, 06:06 PM
Marsdendean Im just saying if i buy cheap disks, i could do them myself!!! Are OEM disks around £100 a pair?
Nooo, don't try it yourself ! Too risky, especially with something like brakes.
05-11-2017, 06:06 PM #387
05-11-2017, 06:11 PM
Didn't Steve and me both just say that getting normal discs drilled was a really bad idea?
05-11-2017, 06:11 PM #388
mikeyb2009
05-11-2017, 06:27 PM
hi there. just been looking through the thread and it looks good :thumbup: cant wait to see it finished. was just wondering what head gasket your using? was going to ask about management too but then saw your post with the emanage ultimate, lol.
mikeyb2009
05-11-2017, 06:27 PM #389
05-11-2017, 06:40 PM
mikeyb2009 hi there. just been looking through the thread and it looks good :thumbup: cant wait to see it finished. was just wondering what head gasket your using? was going to ask about management too but then saw your post with the emanage ultimate, lol.
Thanks :biggrin:. Just using a new OEM head gasket, it's a metal one so should be perfectly up to the job. Yep, e-Manage Ultimate.
Edited 17-12-2009, 10:28 PM by steviewevie.
05-11-2017, 06:40 PM #390
Views 14,780
Views 4,051
Views 4,979
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 176,742
Views 22,871
Views 47,904
Views 144,393
Views 1,342
Views 3,864
Views 6,750
