JapCarForum Car Manufacturers Lexus/Toyota is200 crank pulley
is200 crank pulley
is200 crank pulley
cornishlexus
29-03-2020, 05:27 PM
fitted my new tte bumper the other day and thought i wud do the cam belt while i was at it all was going ok till i tried to undo the crank pulley 3 hours later and tried all i knew and still no joy i know there is a tool for holding the pulley but has anyone got any ideas other than heating it up to crack this off :confused1:
cornishlexus
29-03-2020, 05:27 PM #1
29-03-2020, 05:42 PM
Either an Airgun/12v torque gun or breaker bar onto the floor then turn the engine over.
There is a tool that can be made as ell that goes into the 2 holes to hold it still.
29-03-2020, 05:42 PM #2
cornishlexus
29-03-2020, 05:45 PM
have tried all above and locking flywheel thru starter hole rad and cond off to get my airgun in and is the most powerful snap on make wudnt shift it and having it in first with foot hard on brakes that just made the clutch slip:o
cornishlexus
29-03-2020, 05:45 PM #3
cornishlexus
29-03-2020, 05:49 PM
will have to heat it i think just worried bout damageing the crank seal but think it been loctited in and gunned up and will have to warm it to melt the loctite have had it happen on transits before and broke tools trying to undo them then heat it up and just twists straight of was just seeing if anyone had a clever way of doing it lol
cornishlexus
29-03-2020, 05:49 PM #4
29-03-2020, 06:49 PM
Breaker bar wedged against the floor and trying to start the car has always worked for me!
29-03-2020, 06:49 PM #5
Lance79
02-07-2020, 04:51 PM
All I done to get it loose was put it in 6th gear, five foot pipe over breaker bar and just swing on it till you hear the crack! Give it a soak in penetrating oil the night before and again before you start.
Keep the spark plugs in too.
Lance79
02-07-2020, 04:51 PM #6
01-09-2020, 04:29 AM
I know you hadn't sorted this at Jae mate, but I remembered something I'd seen on mkiiisupra.
You can buy a proper tool like this off eBay;
http://www.zdmak.com/wbstore/main.asp?ac...=1&LowCt=0
Or you can make one:
[Image: 006dc0019d708eb475c54e0811cc09ac.jpg]
[Image: 88d0f911cbc54002ad01b784eafcb898.jpg]
[Image: 633f836c3bf985732204e8d2bc711d80.jpg]
[Image: 047c813399d64e3010b98caf67f969ca.jpg]
Hope that helps.
01-09-2020, 04:29 AM #7
Hope that helps.
01-09-2020, 04:59 AM
Mine is in a similar state, broken 2 breaker bars so far. Of to Halfords for rep;acements lucky they are guaranteed for life lol.
01-09-2020, 04:59 AM #8
cornishlexus
03-09-2020, 07:18 PM
will try and make one at the wekend and give it a go thankx for the help
cornishlexus
03-09-2020, 07:18 PM #9
04-09-2020, 04:07 AM
Did mine yesterday, borrowed a 1" socket and breaker bar, a length of scaffold bar and off it came - the 1" drive is the key as it transfers a lot more torque to the bolt.
04-09-2020, 04:07 AM #10
Views 1,001
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,241
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 588
08-10-2024, 09:10 PM
Views 743
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 22
Views 2,288
26-07-2024, 05:33 PM
Replies 52
Views 4,621
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,295
24-05-2024, 12:47 PM
Views 761
23-05-2024, 07:38 PM
Last Post by ViperTheLex
Views 1,030
19-05-2024, 12:51 PM
