JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Pink furring around waterpump.
Bonney
05-07-2020, 05:36 PM
Just gave my IS200 a good service today, and changed the power steering belt. Whilst I was doing this I noticed that the water pump housing has some furring around the rear of it.
How would I go about re sealing this, Its not on the actual water pump but the upper and lower pipe housings that are coming off it.
Bonney
05-07-2020, 05:36 PM #1
mattlaw
05-07-2020, 07:27 PM
Sounds like the water pump bypass seals, get new ones from a dealer, arnt to bad to fit
mattlaw
05-07-2020, 07:27 PM #2
Bonney
06-07-2020, 09:42 AM
Has anyone got a part number for the seals?
Bonney
06-07-2020, 09:42 AM #3
mattlaw
06-07-2020, 02:45 PM
Put a picture up just to make sure, here's the number for the seals 90301-17009
mattlaw
06-07-2020, 02:45 PM #4
Bonney
10-07-2020, 05:37 PM
Just got a full kit from Lexus to do the job, came to around £40, Comes with the 2 seals, the small peice of pipe and the housing and gaskets, Also ordered a waterpump, Just debating weather its worth changing the thermostat, but like they say If it ain't broke dont fix it!
Bonney
10-07-2020, 05:37 PM #5
mattlaw
10-07-2020, 05:40 PM
We only ever change the seals :confused1:
mattlaw
10-07-2020, 05:40 PM #6
rob
17-07-2020, 06:58 AM
TBH, they tend to leak a bit then stop leaking.
mine has had the pink stain for the last 80 K miles and doesnt leak.
rob
17-07-2020, 06:58 AM #7
Replies 25
Views 1,767
13-05-2021, 07:15 PM
Last Post by James S
