American Sidemarker Mod
![[Image: 408716_3240072861028_1958610216_n.jpg]](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/408716_3240072861028_1958610216_n.jpg)
![[Image: 36315_3240073101034_526957100_n.jpg]](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-prn1/36315_3240073101034_526957100_n.jpg)
![[Image: 523320_3240073701049_1730470735_n.jpg]](https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash3/523320_3240073701049_1730470735_n.jpg)
![[Image: 229586_3240073981056_39312699_n.jpg]](https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/229586_3240073981056_39312699_n.jpg)
![[Image: 560511_3240074581071_2080663265_n.jpg]](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-prn1/560511_3240074581071_2080663265_n.jpg)
![[Image: 564864_3240134502569_690137980_n.jpg]](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash3/564864_3240134502569_690137980_n.jpg)
![[Image: 10469_3197137787678_2098034856_n.jpg]](https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-snc7/p206x206/10469_3197137787678_2098034856_n.jpg)
![[Image: 483263_3197138147687_1825100560_n.jpg]](https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-ash4/483263_3197138147687_1825100560_n.jpg)
![[Image: ormiedit1-2.jpg]](http://i214.photobucket.com/albums/cc320/tempra5/ormiedit1-2.jpg)
The american side marker mod is when the indicators light up as running lights and also flash...
you will need to go to the scrappys and get a stop/tail bulb holder..i got mine from a gs300...and now i shal begin
the bulb holder
now these dont just fit but all you need is a small trim of the lugs
now find out what wire does what...if you get it wrong your indicator will flash fast..
the lexus bulb holder wiring.white/black to white/black(earth)car wiring green/yellow will be spliced into with green/white(indicator feed) and finally green/orange to your side light feed.
once youve wired them in you might want to cover/protect the exposed connector i did this using the finger off one of my blue gloves
now the hard part getting amber double filament bulbs...so heres the answer
now you should be left with this look
and at night
job done...remember solder all joints...scotch locks are work of the devil..
Top write up mate.
![[Image: 429328_3245599359187_1875256925_n.jpg]](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/429328_3245599359187_1875256925_n.jpg)
well for those wanting to do this mod i traced down the proper bulbs
you need to do a slight mod to these bulbs...remove the black plastic clip type bit you can see above the contacts..
ill update the pics soon as i fit the bulbs as they will be more orange.
