JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza is200 Sports wheel, on an SE
Predator
24-08-2020, 05:53 AM
Hi, all
Some of you would know that I have just paid a deposit on a 53 plate is200 SE
Is it difficult to swap the SE steering wheel for the sports steering wheel? Would the airbag cause a problem or is it a direct swap?
Thanks,
John
Predator
24-08-2020, 05:53 AM #1
Hi, all
Thanks,
John
reganlives
24-08-2020, 06:22 AM
As far as I'm aware aren't they exactly the same apart from the colour?
reganlives
24-08-2020, 06:22 AM #2
24-08-2020, 06:41 AM
yep off with one, on with another, no different fittings
24-08-2020, 06:41 AM #3
24-08-2020, 06:45 AM
There's 2 bolts in the sides of the airbag, after there out the airbag pulls out of the wheel. It then needs disconnecting which is 1 clip. After that there's a big bolt which holds the wheel on. Loosen it but don't take it all the way off. to remove the steering wheel loosen the central retaining nut a few threads and give a strong hit to the back of the wheel to release it.
by pulling you are compressing the steering wheel tilt adjuster.
dont forget to disconnect the battery (just incase the airbag goes off) and make sure the wheels are straight before you remove the original wheel.
Edited 05-10-2012, 10:32 AM by is300_dino.
24-08-2020, 06:45 AM #4
Predator
24-08-2020, 06:48 AM
You guys are legends! For what it's worth, reps are on their way Wink
John
Predator
24-08-2020, 06:48 AM #5
John
24-08-2020, 06:56 AM
Just asking but why would you want to swap the wheel I find the SE one in black looks a lot nicer then the 2 tone wheel in the sport
24-08-2020, 06:56 AM #6
Predator
24-08-2020, 08:00 AM
I guess it's just horses for courses.
I like the slight break up in colour. Am I right in thinking the sport wheel is thicker?
I love the feel of a thicker wheel. Look, it even rhymes, lol.
John
Predator
24-08-2020, 08:00 AM #7
John
Matt_C
24-08-2020, 02:57 PM
I think they're the same thickness - could be wrong though!
Matt_C
24-08-2020, 02:57 PM #8
Views 793
12-12-2024, 07:55 PM
Views 868
08-11-2024, 09:35 AM
Last Post by Dinho
Views 1,826
06-11-2023, 07:38 AM
Views 3,948
02-11-2023, 04:43 PM
Views 649
06-08-2023, 05:47 PM
Last Post by Brad92
Replies 38
Views 3,406
23-02-2023, 07:09 PM
Views 668
18-10-2022, 07:53 AM
Views 1,046
03-09-2022, 04:53 PM
Views 796
29-08-2022, 03:48 PM
Replies 35
Views 9,787
04-08-2022, 10:23 AM
Last Post by cjoseph
