JapCarForum Car Manufacturers Nissan Modifications & Tuning Stubby Aerial - Any recommendations?
longsh07
04-09-2020, 11:31 AM
Im looking to replace the standard aerial on my 350Z with a stubby one, mostly for aesthetic reasons. I dont listen to the radio often but when I do the current one cant pick up some stations clearly. Its not like its local radio stations it struggles with either, Radio 1 is the worst!
So yeah, any suggestions for stubby aerials welcome!
OJC Twitter and Facebook
longsh07
04-09-2020, 11:31 AM #1
04-09-2020, 11:42 AM
have you got an aftermarket radio in the car ?
if you have it could be that the antenna power hasn't been connected thus giving you bad reception.....
04-09-2020, 11:42 AM #2
longsh07
04-09-2020, 11:47 AM
Yeah its aftermarket.
Could be that, didn't realise there was an antenna power thought it was just a single cable for the aerial. Pretty sure that cable is connected.
Some stations come through perfectly clear and the right volume, but not others.
longsh07
04-09-2020, 11:47 AM #3
04-09-2020, 12:21 PM
i had this in my IS200 when i swapped from standard to after-market there was a black cable that was the antenna power wire im guessing the same will be in the 350z i have not changed mine from the bose set-up yet so cant comment but i do have the full wiring diagrams so will see what i can find for you
as for the stubby antenna i will see if mine has a make on it lol
04-09-2020, 12:21 PM #4
04-09-2020, 12:24 PM
there is an antenna booster built into the 350z got the guide here so i would say that you have not got that powered up
04-09-2020, 12:24 PM #5
04-09-2020, 12:27 PM
With the ignition switch in ACC or ON, power is supplied
 through 10A fuse [No. 6, located in the fuse block (J/B)]
 to audio unit terminal 10.
Ground is supplied through the case of the antenna amp.
When the radio switch is turned ON, antenna signal is supplied
 through audio unit terminal 5
 to antenna amp. terminal 1.
Then the antenna amp. is activated.
The amplified radio signals are supplied to the audio unit through the antenna amp.
04-09-2020, 12:27 PM #6
04-09-2020, 12:29 PM
to check the wiring at the antenna booster
Remove luggage side finisher lower (LH) (Coupe models) or trunk front finisher (Roadster models).
Remove luggage floor carpet and spare tire cover (Coupe models) or trunk floor carpet and spare tire
cover (Roadster models)
Remove 1 screw to allow easy access to the module to probe
04-09-2020, 12:29 PM #7
longsh07
04-09-2020, 03:32 PM
Cheers Rabs, ill take a look when I get chance.
Sent from my GT-I9100 using Tapatalk 2
longsh07
04-09-2020, 03:32 PM #8
05-09-2020, 11:14 AM
The MR2 guys use S2000 aerials when they're after a stubby replacement. They are also amplified.
http://www.ebay.co.uk/itm/Honda-S2000-Ra...2575a28ec0
Edited 17-10-2012, 02:59 PM by toxo.
05-09-2020, 11:14 AM #9
longsh07
05-09-2020, 11:31 AM
Cheers Toxo.
Surely I wouldn't need the signal amp though if the 350Z has one already?
longsh07
05-09-2020, 11:31 AM #10
Cheers Toxo.
