JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! Supercharger
Supercharger
Supercharger
paddywak
11-09-2020, 10:19 AM
Hi urgent helP needed guys does anyone know if I can run my car with supercharger bolted on plumbed in but with know stand alone ecu or fuel reg just to get me home n back in morning. Ie will airflow meter compensate enough of fueling I don't want it running lean obviously. Any help would be appreciated. You can also ring me 07720744612 ta
paddywak
11-09-2020, 10:19 AM #1
Mikey
11-09-2020, 10:33 AM
could you just take the belt off and run it like that
Mikey
11-09-2020, 10:33 AM #2
paddywak
11-09-2020, 10:43 AM
That was the plan but I've had to move alternator n now or belt won't fit
paddywak
11-09-2020, 10:43 AM #3
P.Lindblom
11-09-2020, 10:50 AM
As long as you don't give it full throttle over 3000rpm you shouldn't hit fuel cut, even if the supercharger is running.
P.Lindblom
11-09-2020, 10:50 AM #4
11-09-2020, 11:05 AM
As Patrik said, just be very careful to keep the revs down and you'll be okay for one journey
11-09-2020, 11:05 AM #5
11-09-2020, 11:33 AM
If you don't have a fuel reg the car won't even start mate.
But your ok without the black box but off high boost/revs obviously.
11-09-2020, 11:33 AM #6
11-09-2020, 11:34 AM
Plus the IS has a pressure sensor not flow.
11-09-2020, 11:34 AM #7
paddywak
11-09-2020, 02:49 PM
Cheers guys got it all plumbed up. Started no probs
paddywak
11-09-2020, 02:49 PM #8
mattlaw
11-09-2020, 04:41 PM
It's an is300 running a vortech supercharger, so does have maf stav, it's also meant to run with an uprated pump plumbed inline with the standard one with a fuel reg and a piggyback ecu to help it all out
mattlaw
11-09-2020, 04:41 PM #9
paddywak
11-09-2020, 04:43 PM
Which it will ASAP :-)
paddywak
11-09-2020, 04:43 PM #10
Replies 209
Views 43,641
06-04-2025, 11:17 PM
Last Post by lexus971
Views 3,562
21-03-2025, 10:24 PM
Views 3,727
07-04-2022, 10:12 AM
Last Post by daveo
Views 2,522
29-08-2021, 03:50 PM
Views 1,789
09-06-2020, 03:51 PM
