subaru impreza wrx low miles 53k great spec
long post alert but here goes
Subaru Impreza wrx wagon in metalic blue, only 53761 miles, wrx version benefits over the uk spec of this year with wingback front seats alloy lightweight bonnet and colour coded door handles and skirts,car was registered in the uk in 2000, this is a 240hp motor as standard and comes with a td04 from the factory, 3 previous owners and i have owned this car for over 7 years,the last 5 of which it has been running at the following spec,..
TD05 turbo polished housing and ported inlet.
Ported and heat wrapped Harvey Smith up pipe.
Ported and heat wrapped manifolds.
Bell mouth decat down pipe into a catted center section with a Jap innovations 4.5 inch rolled edge tailpipe.
Later new age intercooler fitted with samco boost pipe, tilt kit and boost activated water spray.
Forge dv fitted, splitter fitted to scoop to direct air to all of intercooler surface.
Breather catch can in engine bay along with polished radiator air flow panel, polished fuse box cover and air box trim.
Green cotton air filter in standard airbox but resonator pipe work removed and cold air feed pipe running from front bumper area to rear of airbox.
Walbro 255lph fuel pump.
Earthing kit fitted to major points around the engine bay and also into ecu area for better grounding.
3 port boost solenoid fitted.
Apexi pfc ecu with hand commander mapped by Simon Rowe aka jolly green monster at 1.3 bar on V power and always run on the same.
E Tech strut brace fitted to front and car has pink STI suspension fitted all round.
Orange indicator lens have been replaced with clear, and the rear lamps are also of the clear STI type which are rare. Interior is in very good condition, no rips or tears just one small cigarette burn on the drivers seat base from a previous owner.
Center guage pod fitted with autoguage boost, oil temp and oil pressure guages, and a A pillar guage on the drivers side that monitors air fuel ratio.
Also have a guage that monitors air temp into the inlet manifold after the intercooler.
A turbo timer is also installed.
Limited edition short shifter fitted with numbered plaque on the center console.
Everything works including the air con.
Externally the body work for its age is in great condition, one small dent by drivers front side repeater,and rear bumper has scrapes on both edges,but nothing major for a 13 year old car,rest is in realy good nick,polishes up lovely.
Privacy glass to rear.
Currently has RB5 alloys fitted with excellent tyres with lots of tread.
Brakes are subaru 4 pots with drilled and grooved Black Diamond discs.
Electric windows x4
Electric operating and folding mirrors
Car drives faultless and really belies its age, i have lots of receipts, old mots etc to verify the milage,though a simple vosa check will confirm its genuine, cambelt changed at 34000, oil changed twice a year filter once a year, mot to march 2013 tax till end of the month, though may tax again and have no problem putting a fresh 12 month mot on the car for the new owner as im very confident it will sail through as it has done in all the previous years ive owned the car
Thatcham cat 1 alarm fitted
Car located in Birmingham not far from J4 M42
New car forces sale
£3200 ono
Now with a fresh full 12 month mot
70 pics of all over the car here. ,...
http://s6.beta.photobucket.com/user/rigg...20impreza/
Contact Martin on 07739966741
Price drop to £2950
To answer the often quoted "how much power " question. A td05 with 440cc injectors has the Max potential of around 340hp this car running at 1.3bar and roughly 92 % injector duty cycle should be in the region of 320hp give or take, its certainly not slow in the slightest.
Photobucket link doesn't work, should be http://s6.beta.photobucket.com/user/rigg...20impreza/
I've passed the link to this thread onto a friend who's after one.
