JapCarForum Trade Area Wanted suspension top mounts
john wan
01-01-2022, 05:41 PM
As title im after some top mounts as ive had an idea
Edited 12-02-2014, 09:27 PM by john wan.
john wan
01-01-2022, 05:41 PM #1
Tosh21
16-01-2022, 04:59 PM
what you thinking? I may be able to help you
Tosh21
16-01-2022, 04:59 PM #2
john wan
16-01-2022, 05:11 PM
Im thinking ive found diffrent pair of shocks that I wanna fit some top mounts to so I can see if they work on the car without stripping down my ones on the car
john wan
16-01-2022, 05:11 PM #3
Tosh21
16-01-2022, 05:36 PM
are they aftermarket shocks? i think the fronts will be fine with the standard top mounts but the rears won't. I was gonna offer you my old ones if you wanted to copy it or test fit something but they dont have any studs so pretty usless in this case :/
Tosh21
16-01-2022, 05:36 PM #4
john wan
16-01-2022, 05:44 PM
Not aftermarket just off a heavier car offered up to my lowered kit there 10/20mm shorter than my standard shocks with 50mm lowering springs on an the body is thicker
john wan
16-01-2022, 05:44 PM #5
Tosh21
16-01-2022, 05:55 PM
oh ok, you could measure the od of the shaft under the dust boot on your standard one and compare with the new one. And the spring seat might be a bit bigger so the spring wont sit properly. Apart from that they should go on no problems
Tosh21
16-01-2022, 05:55 PM #6
john wan
16-01-2022, 06:04 PM
The sprung thats come with the shock looks to be alot thicker to if they work ok theyl be a propper cheap way to lower an stiffen up stuff on the lex eh skid skid win win
john wan
16-01-2022, 06:04 PM #7
Tosh21
16-01-2022, 06:10 PM
as long as the ID of the spring is the same as the your lowering springs then your good to go. It's definately worth a try! coils are soooo expensive for them
Tosh21
16-01-2022, 06:10 PM #8
john wan
17-01-2022, 04:09 PM
Yeah id is the same length is the same to just position of the spring seat is diffrent its a bit lower down
john wan
17-01-2022, 04:09 PM #9
Views 185
31-12-2020, 06:16 PM
Last Post by john wan
