JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! DIY: Auto folding mirrors
Pages (3): 1 2 3 Next
lex2oos
01-04-2022, 05:27 AM
Hi there!
I wanted mirrors that fold automaticly and unfold when car is locked and unlocked for a long time. I tought about making electronics myself, but found a module on ebay that should do what I needed and it was 12$, so I tought I should give it a try and ordered it.
This is what came in the box + installation manual:
(Stole a pic from amazon)
[Image: 4141x-gMjfL._SY300_.jpg]
Unit features:
-It folds mirrors when car is locked (manual says mirrors will fold after 5min if IGN is off without locking, but haven't tested this)
-Can be wired in to unfold when unlocked, or unfold only when ignition (ACC) is switched on.
-Mirrors will not fold with door locks IF ignition is ON, but will operate (fold/unfold) normal with mirror folding button on door switch.
Installation:
here is wiring diagram that came with the unit:
[Image: 57B0185E-819A-464B-9DE1-9155EAF8AA15.jpg]
as you can see, unit has 9 wires with descriptions. you will need to cut original wires that go from the switch to mirrors and pass them trought the unit for it to operate, as you can see in diagram.
here is IS200 folding mirror wiring diagram (sorry about russian language):
[Image: 60e136b8-9568-41f4-835c-12e28ae31c78.jpg]
You need to cut Ygr and Ygr-R wires and connect them like this:
[Image: 1DE4ADD9-4ECD-4809-A3F1-D1C60B2B4781.jpg]
Ygr goes trough Grey and Orange
Ygr-R goes trough White and Brown
Yellow wire (IGN) is connected to Gr (gray - pin9).
For Constant power, ground and lock signal master window switch connector is used:
[Image: bb006008-8bef-4b52-a090-3c49c8b73758.jpg]
RED wire from unit goes to POWER
BLACK wire goes to GROUND
BLUE wire from unit goes to DOOR LOCK SIGNAL
With this wiring mirrors will fold when car is locked, but will unfold only when ignition is switched to ACC position, because Green wire (unlock signal) is left disconnected because unlock signal cannot be found on window switch connector.
If you want to have mirrors that unfold when unlocked, door panel has to be taken off.
I think everyone that has some common understanting can do this job.
there are other simmilar modules on ebay for more money, but they look identical to one i bought, so why pay more...
This is where I bought mine:
http://www.ebay.com/itm/New-Car-Side-Mir...2ecd681300
Good luck!
Hope this was helpful.
lex2oos
01-04-2022, 05:27 AM #1
Hi there!
Unit features:
Installation:
Good luck!
Millo73
01-04-2022, 06:37 AM
Looks easy enough job thanks to your guide
MeisterR low and hks silent is how to ride
Millo73
01-04-2022, 06:37 AM #2
lex2oos
01-04-2022, 04:37 PM
If someone could correct title to "mirrors", that would be great...
lex2oos
01-04-2022, 04:37 PM #3
01-04-2022, 05:09 PM
tittle corrected shame the seller wont ship to the uk Sad
01-04-2022, 05:09 PM #4
Millo73
01-04-2022, 05:16 PM
Check here I've just ordered this one
http://www.aliexpress.com/item/Side-view...or-shkmail
Sent from AliExpress
Millo73
01-04-2022, 05:16 PM #5
Millo73
06-04-2022, 03:34 PM
Well I have followed your step by step guide and nothing
[Image: asuze7y4.jpg][Image: pa2ysyze.jpg][Image: hetyvade.jpg][Image: huzygave.jpg][Image: rezy3ane.jpg]
Please advise as now stuck
Thanks
Gary
Millo73
06-04-2022, 03:34 PM #6
Thanks
Gary
lex2oos
07-04-2022, 07:20 AM
Sorry to hear that...
I sent you a private message with some troubleshooting step-by-step, hope it will help.
IF anyone from here is ordering similar kit, compare my wiring diagram to yours, there could be changes to pinout or wire colors, so keep that in mind and be careful.
lex2oos
07-04-2022, 07:20 AM #7
Millo73
07-04-2022, 08:08 AM
All sorted and works a treat thanks to lex2oos top bloke 😊😊😊😊😊😊😊😊😊😊😊
Millo73
07-04-2022, 08:08 AM #8
07-04-2022, 09:34 AM
Glad you got it working mate!
07-04-2022, 09:34 AM #9
Millo73
07-04-2022, 09:37 AM
Cheers it was doing my head in but I connected to wrong wire for remote
Millo73
07-04-2022, 09:37 AM #10
 3 Guest(s)
 3 Guest(s)
Replies 31
Views 4,442
07-03-2019, 09:49 AM
Views 991
10-01-2019, 02:52 PM
