JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! GReddy emanage blue
GReddy emanage blue
GReddy emanage blue
hp_zim
07-05-2022, 07:21 AM
Does anyone know the GReddy emanage blue piggyback well, or perhaps know a tuner who works with this well?
I am trying to find out how they disable the standard ecu closed-loop lambda control as I've heard that its been done before with the emanage blue.
hp_zim
07-05-2022, 07:21 AM #1
reganlives
07-05-2022, 08:34 AM
I've heard that Tuning developments in warrington are good with this.
reganlives
07-05-2022, 08:34 AM #2
07-05-2022, 01:54 PM
I've also heard a lot of bad things about tuning developments. In fact, there is a thread on that very subject over on driftworks.
07-05-2022, 01:54 PM #3
07-05-2022, 03:42 PM
You won't be able to do it with a basic piggyback like the blue, esp on the lexus
07-05-2022, 03:42 PM #4
daveo
08-05-2022, 05:13 AM
I see you came over from tezza worldSmile
stav you seem to know a bit about these. can you suggest one for us that we would be able to use. on ebay they all look the same to me as I don't understand them. ive asked a lot of people and seem to get no answers. do you know anyone that can point me in the right direction if you don't know yourself bud.
daveo
08-05-2022, 05:13 AM #5
08-05-2022, 12:14 PM
Not sure how complex the tezza ecu is. With thee Lexus it constantly adjusts so can negate the piggyback over time.
In theory the ecu needs to be able to output to the standard O2 sensors signals that go to the ecu and tell the ecu everything is rosey. Whilst also take the signal from the sensor to control the fuel.
I'd have to look into it a bit deeper and see of the emanage can simulate a O2 sensor and do it's own closed loop mapping.
08-05-2022, 12:14 PM #6
08-05-2022, 12:18 PM
yes it can. as thats how mine has been set up to run
08-05-2022, 12:18 PM #7
08-05-2022, 01:06 PM
There you go then!
08-05-2022, 01:06 PM #8
There you go then!
08-05-2022, 01:30 PM
but if you have double lambda sensors you will need to make them into one. you do this inside the ecu box. you just hot wire them as one unit
08-05-2022, 01:30 PM #9
hp_zim
09-05-2022, 11:24 AM
I have read up on the emanage blue document and the lambda sensor wiring into the unit only seems to be for data monitoring, there is no control option based on lambda input
hp_zim
09-05-2022, 11:24 AM #10
