JapCarForum Car Manufacturers Lexus/Toyota supercharged is200 cuts power at 80mph?
tim996
30-08-2022, 07:09 AM
Hey guys supercharged Lexus recently its ran fine for about 4 weeks, now whenever I go over 80 mph it seems to go into some sort of limp mode? Running patrik black box and bypass and ssqv, the throttle just goes all fluffy and you can still drive but with very little power, I pull over turn car off and on again and its cured till I go over 80mph again???? Any help much appreciated I think it must be a sensor?
tim996
30-08-2022, 07:09 AM #1
Lance79
30-08-2022, 09:35 AM
I've never heard of this issue where it goes to limp mode at 80mph. The only thing that you can really check is the tension on the bypass cable, whenever I first installed my supercharger it went to limp mode whenever I buried the throttle. To fix it the bypass cable at rest must have a bit of slack, a fingers width is the general measurement.
Something like this is right. If it's not that then I would check your connections to the black box, or contact Patrick as the box may be playing up, although I've never really heard of his version giving problems unlike the TTE and FCD versions.
[Image: P2100001.jpg]
Lance79
30-08-2022, 09:35 AM #2
tim996
30-08-2022, 10:18 AM
Cheers for the reply, im running a mini bypass valve controled by vacuum line, the bypass seems to be running good and dumping air when it should, its just really strange that anything over 80 trips it into limp mode, I have no engine warning lights on dash either when it does it, will have to check wiring and go from there,
tim996
30-08-2022, 10:18 AM #3
13-09-2022, 06:18 PM
are you running bigger injectors or the standard IS200 ones?
13-09-2022, 06:18 PM #4
tim996
14-09-2022, 05:01 AM
Running standard injectors which I thought would be fine, also still running standard manifold too, sometimes if you accelerate straight past 80mph and carry on its ok but if you sit around 85mph thats when its most likely to trip? When it dies you can only use about 10 percent of the throttle and no warning lights, very strange, could it be map sensor?
tim996
14-09-2022, 05:01 AM #5
15-09-2022, 01:43 PM
Probably not giving you enough fuel. Stick bigger injectors in and see if it still does it.
15-09-2022, 01:43 PM #6
18-10-2022, 07:46 AM
i had a similar issue on my turbo IS200
did you get this solved ?
18-10-2022, 07:46 AM #7
tim996
19-10-2022, 02:55 PM
Yeah fixed problem a while back, I originally mounted the mini bypass valve just before the elbow into the throttle body, it must have been to close to the trottle body cause when I moved it across the engine bay towards the charger it completely fixed the problem, I can only guess that the sudden drop in pressure was tripping out a sensor somewhere, runs sweet now!!
tim996
19-10-2022, 02:55 PM #8
28-10-2022, 11:27 AM
excellent news
whats next for the car ?
28-10-2022, 11:27 AM #9
excellent news
tim996
29-10-2022, 04:52 AM
Definently wheels next and a turbo conversion keeps playing on my mind! Got a taster session booked for snetterton this saturday so will see how the lexus goes on track, what car you got rabster?
tim996
29-10-2022, 04:52 AM #10
Views 1,001
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,241
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 588
08-10-2024, 09:10 PM
Views 743
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 22
Views 2,288
26-07-2024, 05:33 PM
Replies 52
Views 4,621
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,295
24-05-2024, 12:47 PM
Views 761
23-05-2024, 07:38 PM
Last Post by ViperTheLex
Views 1,030
19-05-2024, 12:51 PM
