New auto rae-chem clay mitts
![[Image: CLAYMITT-FINE-USE_zpse4ea216b.jpg]](http://i107.photobucket.com/albums/m298/rachelwillie/CLAYMITT-FINE-USE_zpse4ea216b.jpg)
![[Image: CLAYMITTFINEUSE_zps1f382c8f.jpg]](http://i107.photobucket.com/albums/m298/rachelwillie/CLAYMITTFINEUSE_zps1f382c8f.jpg)
AUTO RAE-CHEM MEDIUM GRADE CLAY MITT
PRICE DELIVERED @ £10.99
AUTO RAE-CHEM FINE GRADE CLAY MITT
PRICE DELIVERED FINAL TOUCH 1L @ £7.99
PRICE DELIVERED VALETPRO CITRING BLING @ £8.99
AUTO RAE-CHEM Fine Grade Detailing Clay Mitt
Very quick and easy to use
Removes bodywork contaminants and overspray
Removes contaminants and overspray quicker and easier than finer grades
If dropped wash off in bucket of soapy shampoo
More durable than a traditional clay bar, lasting up to 5x longer
More Information
A quick and effortless detailing system that achieves professional showroom perfect shine results using advanced rubber polymer technology. This is a process which gives the same effect as Clay Bars as used in professional body shops. The Clay Mitt is safe and easy to use, removing paint overspray, water spots, fresh tree sap, rail dust and other bonded surface contaminants from the surface of automotive paint, glass, mouldings and plastic.
The Clay Mitt can be cleaned and re-used by simply rinsing off the accumulated contaminants with water. The design of the Clay Mitt surface allows for an effortless easy gliding action over the surface when used with appropriate detail solutions such Valetpro Citrus Bling. If neither of these is available water can also be used however results will not be as good.
To wash, simply rinse in water and hang to dry. Do not tumble dry!
DIRECTIONS
Before you start:
For use on a clean, cool paint surface and out of direct sunlight. DO NOT use on surfaces over 62ºC. First test on an inconspicuous part of the bodywork before use. Avoid dropping on the floor and picking up any dirt, but if you do, simply rinse off in clean water.
Method:
Thoroughly wash the vehicle free of dust, sand and dirt ensuring you remove any tar and grease before starting.
Soak the Clay Mitt in your chosen solution and then gently rub the Mitt over the surface with a light, even back and forth action. Keep both the Mitt and vehicle surfaces well lubricated whilst working to achieve best results.
Wipe off residue with a clean Micro Fibre cloth to reveal a protected and smooth as glass surface. Repeat same procedure over entire vehicle.
Pay with either paypal or credit cards
These look amazing!
