JapCarForum Car Manufacturers Lexus/Toyota 1st post and its a cry for help. Lexus IS200 sport problems.
atacam
07-12-2022, 03:09 PM
Hi Guys. Just found this forum.
OK I'm not technical so please bare with me.
Parked up the car last night, nothing unusual, locked with the fob, OK and I went in.
Came out this morning, unlocked the car, with the fob and noticed it took a second or two for the lights to blink.
Went to start the car, the alarm went off.
Hit the lock on the fob, after a short pause the car alarm stopped and car locked but no lights blinked
Tried it a few times lock, unlock, and the same.
When unlocking the car there is a pause then the lights blink and the car unlocks, lock it, no blink but I can hear it lock.
If I put the key in the ignition, the security light goes out as normal, but the alarm goes off if I start the car, but turns off after 10secs.
I also noticed that there is a capital 'E' where my temperature should be and the fuel gauge is reading empty with the petrol light blinking like a madman, although I know I have about half a tank.
Changed the battery in my fob, no change. Checked the petrol filler hole and wiggled the white collar inside, no change.
It's almost like the car thinks about unlocking then does but doesn't switch off the alarm.
Just took out the battery and found it to be very low and in need of charging. I did also notice that the on auto the lights stay on and the car is saying that a door is open, when I checked them all and they are shut, boot and bonnet too.
Any ideas at all please? Sad
atacam
07-12-2022, 03:09 PM #1
07-12-2022, 04:06 PM
The flashing light and gauge sounds like a fault with one of the senders. They measure the tank level and are accessed under the rear seat.
Though with the alarm issue could be the speedo itself causing you problems.
The E on the temp means there is an error, could be the sensor unplugged? Has the bumper been off? May not have reconnected it.
07-12-2022, 04:06 PM #2
07-12-2022, 04:07 PM
Ahh just read the last sentence properly, the lights staying on means your theft unit is knackered under the dash or there's water in the footwell fusebox. Has the car had a new windscreen?
07-12-2022, 04:07 PM #3
atacam
07-12-2022, 04:42 PM
Oh. No. Windscreen has been in there for ages. Not been any rain last night either, although I suppose it could be caused by condensation?
atacam
07-12-2022, 04:42 PM #4
Views 1,001
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,241
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 257
07-12-2024, 07:31 PM
Last Post by yaser01
Views 588
08-10-2024, 09:10 PM
Views 743
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 22
Views 2,287
26-07-2024, 05:33 PM
Replies 52
Views 4,621
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,295
24-05-2024, 12:47 PM
Views 761
23-05-2024, 07:38 PM
Last Post by ViperTheLex
