JapCarForum Car Manufacturers Toyota Yaris 1.0 2000 misfire
Pages (3): 1 2 3 Next
rob
12-07-2023, 01:24 PM
Hi all..
Fault light came on this morning.. fault code is cylinder 1 misfire.
I swapped the coil packs.. stays on cyl 1. Swapped the plugs and stays on cyl 1.
Anyone had similar problem?
I have to check the wiring harness next.
rob
12-07-2023, 01:24 PM #1
Hi all..
rob
12-07-2023, 02:25 PM
It's not the plugs or the coil pack.. The plug also sparks... mmmmmm deeper troubles ahead!!
Anyone got a link for an engine repair manual?
rob
12-07-2023, 02:25 PM #2
12-07-2023, 06:02 PM
Hmm could be the ecu, a part broken, hopefully just a broken wire!
12-07-2023, 06:02 PM #3
rob
13-07-2023, 02:45 AM
Yep that's what I'm hoping... I will try get a compression test today then it rules out the mechanical part. It's only done 50k miles so shouldn't be valves but never know.
rob
13-07-2023, 02:45 AM #4
13-07-2023, 09:43 AM
Surely wouldn't show a code if a mechanical issue?
13-07-2023, 09:43 AM #5
rob
13-07-2023, 01:36 PM
Compression test results... ZERO compression on cylinder 1.... ****!
The system is obviously smarter than I am.. not sure what it's picking up or from where.
I did notice it was down on power a few months ago but put it down to 40c and air con on.. I guess that was the start of it. I'm hoping it's just a burnt valve. I will get a boroscope in there tomorrow morning hopefully it should be obvious. Hoping it's not rings etc.
rob
13-07-2023, 01:36 PM #6
14-07-2023, 08:31 AM
gutted mate, hope its not too bad a fix
14-07-2023, 08:31 AM #7
rob
14-07-2023, 10:54 AM
It's a good days work but I'm going to strip the head fully and get it in the ultrasonic cleaner so takes but longer.
rob
14-07-2023, 10:54 AM #8
rob
15-07-2023, 11:26 AM
Quick look inside reveals the problem... also some slight burning on number 4.
[Image: f82c32717fdeecf02af183d0ee70bf3d.jpg]
rob
15-07-2023, 11:26 AM #9
15-07-2023, 01:41 PM
Not good!
15-07-2023, 01:41 PM #10
Not good!
Views 1,893
18-07-2020, 11:08 AM
Views 609
26-06-2020, 03:47 PM
Views 2,651
23-06-2018, 02:32 PM
Last Post by ormi
Views 1,442
26-05-2018, 06:04 PM
Views 812
26-02-2018, 08:51 AM
Last Post by Bandit
Replies 22
Views 2,419
18-08-2017, 06:32 PM
Views 1,033
14-07-2017, 06:40 AM
