JapCarForum Car Manufacturers Lexus/Toyota Is200 geometry settings?
rob
02-12-2023, 02:04 PM
Hi all,
I can't find the revised geo settings from WIM. Does anyone have a link?
rob
02-12-2023, 02:04 PM #1
Hi all,
02-12-2023, 03:19 PM
Think he charges for them now, it's only a nominal amount though.
02-12-2023, 03:19 PM #2
rob
02-12-2023, 07:09 PM
Sparkystav Think he charges for them now, it's only a nominal amount though.
Ok I will have another look at the site if I can find details. Cheers
rob
02-12-2023, 07:09 PM #3
rob
02-12-2023, 07:37 PM
Found them:
REAR
Camber: 55’ Negative
Toe: 6’ Positive (partial)
Thrust: 0. Or as near to but no more than 5’
FRONT
Camber: 10 to 15’ Negative
Castor: 6 Degrees Positive if possible + - 30’*
KPI/ SJI: even +- 30’
Included angle: - not relevant (unless uneven by more than 45’)
Toe: 4’ Positive (partial)
rob
02-12-2023, 07:37 PM #4
Found them:
REAR
FRONT
02-12-2023, 07:41 PM
Awesome!
02-12-2023, 07:41 PM #5
Awesome!
reganlives
04-12-2023, 04:06 PM
I have them in my email. Will dig them out as there are two lots of setting's doing the rounds on the internet and Tony himself confirmed mine were right.
Sent using Tapatalk
reganlives
04-12-2023, 04:06 PM #6
Sent using Tapatalk
reganlives
04-12-2023, 04:10 PM
Here you go...
Front
Rear
Point to note if the castor ends up higher than suggested that’s nothing to worry about.
Sent using Tapatalk
reganlives
04-12-2023, 04:10 PM #7
Here you go...
Front
Rear
Sent using Tapatalk
05-12-2023, 05:53 AM
That's the same as above. But at least they are the correct .
Well done in sharing this :biggrin:
05-12-2023, 05:53 AM #8
rob
05-12-2023, 11:54 AM
I finally found a garage that has a clue and will adjust to settings outside of what it says on the computer. Tony says the results are looking good.
rob
05-12-2023, 11:54 AM #9
13-12-2023, 10:50 AM
cant beat good info Smile
13-12-2023, 10:50 AM #10
Views 1,009
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,261
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 590
08-10-2024, 09:10 PM
Views 749
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 22
Views 2,311
26-07-2024, 05:33 PM
Replies 52
Views 4,658
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,305
24-05-2024, 12:47 PM
Views 766
23-05-2024, 07:38 PM
Last Post by ViperTheLex
Views 1,037
19-05-2024, 12:51 PM
