JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! Headlight Baking
Headlight Baking
Headlight Baking
Niliano
17-03-2024, 07:15 AM
Hi Guys,
I recently put new LED halos in the lexus however the lens hasn't really fitted in properly so want to redo it!
Can I put the headlight back in the oven with the LED halos still in? As the wires are coming out will they be ok?
What temp should I do it for and how long?
I was doing it at 100 in a fan oven for 1.30 mins
Just worried ill kill the new halos!
Thanks in advance Smile
Niliano
17-03-2024, 07:15 AM #1
Hi Guys,
P.Lindblom
17-03-2024, 08:03 AM
Your halos will be fine, mate. 10-15 minutes in 100-115°C should be enough to loosen up the glue and it's not near enough to hurt your LEDs. Just make sure your oven has reached the specified temperature before you bake your headlight, otherwise the heat might be a bit too intense.
P.Lindblom
17-03-2024, 08:03 AM #2
Niliano
17-03-2024, 08:07 AM
ok wicked
thanks a lot Smile was very worried haha
Niliano
17-03-2024, 08:07 AM #3
ok wicked
is200turbo
17-03-2024, 11:10 AM
P.Lindblom Your halos will be fine, mate. 10-15 minutes in 100-115°C should be enough to loosen up the glue and it's not near enough to hurt your LEDs. Just make sure your oven has reached the specified temperature before you bake your headlight, otherwise the heat might be a bit too intense.
I will second that as when I put my LED eyes in they went back in the oven to reseal the lights and never had a problem with all the lights workin
is200turbo
17-03-2024, 11:10 AM #4
Niliano
19-03-2024, 06:50 AM
Wicked so what do you recommend I stick the rings down with? The kit came with sticky pads but they aren't that great..was thinking silicone or super glue?
Niliano
19-03-2024, 06:50 AM #5
is200turbo
19-03-2024, 06:51 AM
I used the pads supplied and also a bit of silicone just to make sure
is200turbo
19-03-2024, 06:51 AM #6
Niliano
Wicked
Niliano
19-03-2024, 06:51 AM #7
Wicked
