JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! IS200/300 - Chrome steering wheel emblem from airbox
P.Lindblom
09-10-2017, 11:52 AM
I know there is already a thread discussing this mod, but not in the workshop area, so here we go Smile
Obviously you need an emblem to replace your standard one with. A few people have used the wheel center cap emblems from Lexus IS/GS 2006 onwards. I did it a bit differently Smile
This is the standard IS200/300 steering wheel
[Image: dsc7643fix.jpg]
The rubber emblem is glued to the steering wheel, but it's easy to remove once you get hold of its edge.
[Image: dsc7646fix.jpg]
This is what it looks like when the emblem is removed.
[Image: dsc7660fix.jpg]
Now you need another emblem that fits perfectly. As mentioned, the center cap emblems from Lexus IS and GS from 2006 onwards will work, but if you own an IS200 you are already in possession of an even better alternative, the stock air box.
[Image: dsc7632fix.jpg]
I didn't even know the emblem could be removed until I tried. It was easier than I thought, the emblem is attached with double sided adhesive tape.
[Image: dsc7634fix.jpg]
[Image: dsc7636fix.jpg]
This is why the airbox emblem is better than the center cap ones. Not only do you get the emblem, but you also get a perfectly shaped cap so you won't have to make your own.
[Image: dsc7640fix.jpg]
[Image: dsc7648fix.jpg]
Now it's time to fit the new emblem. If your lucky the adhesive that's already attached to the emblem is in good enough shape to use. I chose to scrape it all of and add my own tape.
[Image: dsc7657fix.jpg]
Before you fit the emblem you might want to remove the horn fuse to avoid annoying your neighbors Smile
[Image: dsc7649fix.jpg]
Voila! The steering wheel suddenly looks a lot more modern.
[Image: dsc7662fix.jpg]
P.Lindblom
09-10-2017, 11:52 AM #1
09-10-2017, 12:35 PM
excellent pics mate,
did you hacve to trim your badge at all?
09-10-2017, 12:35 PM #2
P.Lindblom
09-10-2017, 01:00 PM
Sparkystav excellent pics mate,
Thanks mate,
Mine was a perfect fit, but when I did the same thing on another car the emblem was just a tiny bit too large. However, the steering wheel is quite soft and the edges are really easy to cut with a sharp knife.
P.Lindblom
09-10-2017, 01:00 PM #3
Thanks mate,
11-10-2017, 08:35 AM
me just used a wee file on the badge and trimmed it down that wey. great write up and thanks for this mod it works really well if you have the stainless dials,a/c rings and the clock face.
11-10-2017, 08:35 AM #4
TommyH
11-10-2017, 08:40 AM
I just swapped the logo's over, steering wheel one looks fine on box.
TommyH
11-10-2017, 08:40 AM #5
13-03-2018, 09:12 AM
Well I was just about to do this also but the one I have got is not the same.
There is no black behind the L so I think I'll need a different badge now
13-03-2018, 09:12 AM #6
Anees
13-03-2018, 06:35 PM
Can't you just stick it over your existing emblem Moley?
Alternatively, get a bit of old leather, stick the badge to that, then cut around it and stick to the steering wheel....... (I did thing with the Aristo I used to have)
[Image: clubbanner.gif]
Anees
13-03-2018, 06:35 PM #7
13-03-2018, 06:42 PM
A bit of old black leather sounds like a plan Anees.
Just away to cut up one of Mrs Moley's leather jackets :thumbup1:
13-03-2018, 06:42 PM #8
13-03-2018, 06:48 PM
Moley A bit of old black leather sounds like a plan Anees.
Not your own leather chaps then? Big Grin
13-03-2018, 06:48 PM #9
Views 407
13-12-2023, 11:46 AM
Replies 46
Views 9,654
16-03-2023, 05:51 AM
Last Post by Emissary
Replies 25
Views 6,312
17-08-2020, 12:21 PM
Last Post by Johny47
Views 963
24-01-2020, 07:55 PM
Views 3,259
03-10-2019, 02:22 PM
Replies 24
Views 3,805
19-07-2019, 04:46 PM
Replies 41
Views 5,133
10-04-2019, 05:07 AM
Last Post by IanS200
Views 1,131
23-01-2019, 01:07 PM
Last Post by Jambo
Views 3,251
27-10-2018, 12:03 PM
