JapCarForum Car Manufacturers Nissan Modifications & Tuning The skyline spec
The skyline spec
The skyline spec
18-05-2017, 07:17 AM
Some of the standard spec on each car:
R32GTST Specifications
Dimentions
Length 4580 mm
Width 1695 mm
Height 1340 mm
Wheelbase 2615 mm
Turning Circle 5.2 m
Chassis & Body
Curb Weight 1320 KG
Body Type 4 door sedan or 2 door coupe
Layout Front engine / Rear wheel drive
Wheels 16 x 6.5
Tyres 205/55 R16
Brakes Ventilated: 4 pot front, 2 pot rear, ABS optional
Steering Rack & Pinion speed sensitive (front) HICAS (rear)
Suspention F/R Independent multilink
Engine
Type RB20DET- Inline 6, Twincam, turbo intercoolered
Displacement 1998cc
Compression Ratio 8.5.1
Power 158 KW @ 6400 RPM (115 to 125rwkw)
Torque 263NM @ 3200 RPM
Bore x Stroke 78 x 69.7
Redline 7,500 RPM
Fuel Injection Nissan EGI (ECCS)
Fuel Tank Capacity 60 litres
Gearbox 5 Speed Manual
Performance
0-100 6.5 seconds
0-400m 14.8 seconds
R32GTR Specifications
Dimentions
Length 4545mm
Width 1755mm
Height 1340mm
Wheelbase 2615mm
Turning Circle 10.6 m
Chassis & Body
Curb Weight 1430kg
Body Type 2 door coupe
Layout Front engine / All wheel Drive (ATTESSA)
Tyres F&R 225/50R16 92v
Brakes Front - 324mm ventilated, 4-piston calipers
Rear - 300mm ventilated, 2-piston calipers
Engine
Type RB26DETT- Inline 6, Twincam, Twin turbo intercoolered
Displacement 2568 cc
Compression Ratio 8.5:1
Power 206kW @ 6800rpm
Torque 353Nm @ 4400rpm
Bore x Stroke 86mm × 73.7mm
Redline 8,000 RPM
Fuel Tank Capacity 72 litres
Performance
0-100 4.7 seconds
0-400m 12.9 seconds
R33GTST Specifications
Dimentions
Length 4640 mm
Width 1720 mm
Height 1340 mm
Wheelbase 2720 mm
Turning Circle 10.4 m
Chassis & Body
Curb Weight 1360 KG
Wheels 16 x 6.5
Tyres 205/55 R16 or 225/50 R16
Engine
Type RB25DET- Inline 6, Twincam, turbo intercoolered
Displacement 2498
Compression Ratio 9.0.1
Power 187 KW @ 6400 RPM (130 to 140rwkw)
Torque 295NM @ 4800 RPM
Bore x Stroke 86.0 x 71.7
Redline 7,000 RPM
Fuel Tank Capacity 65 litres
Performance
0-100 6.18 seconds
0-400m 14.4 seconds
R33GTR Specifications
Dimentions
Length 4675mm
Width 1780mm
Height 1360mm
Wheelbase 2720mm
Turning Circle 11.4 m
Chassis & Body
Curb Weight 1530kg
Tyres F&R 245/45ZR17
Steering Rack & Pinion speed sensitive (front) Super HICAS (rear)
Engine
Torque 375Nm @ 4400rpm
Redline 8,000 RPM
Performance
0-100 5 seconds
0-400m 13.1 seconds
R34GTT Specifications
Dimentions
Length 4580 mm
Width 1725 mm
Height 1340 mm
Wheelbase 2665 mm
Turning Circle 10.2 m
Chassis & Body
Curb Weight 1410 Kg
Wheels 17 x 7.5
Tyres 225/45
Engine
Type RB25DET- Inline 6, Twincam, turbo intercoolered NEO
Displacement 2498
Power 206 KW @ 6400 RPM (140 to 150rwkw)
Torque 343NM @ 3200RPM
Redline 7,000 RPM
Performance
0-100 6.2 seconds
0-400m 14.3 seconds
R34GTR Specifications
Dimentions
Length 4600mm
Width 1785mm
Height 1360mm
Wheelbase 2665mm
Turning Circle 11.2 m
Chassis & Body
Curb Weight 1540kg
Tyres F&R 245/40ZR18
Engine
Torque 400Nm @ 4400rpm
Redline 8,000 RPM
Transmission 6 speed Getrag
Performance
0-100 4.9 seconds
0-400m 12.9 seconds
18-05-2017, 07:17 AM #1
Dimentions
Length 4580 mm
Width 1695 mm
Height 1340 mm
Wheelbase 2615 mm
Chassis & Body
Curb Weight 1320 KG
Wheels 16 x 6.5
Tyres 205/55 R16
Engine
Displacement 1998cc
Redline 7,500 RPM
Performance
0-100 6.5 seconds
0-400m 14.8 seconds
Dimentions
Length 4545mm
Width 1755mm
Height 1340mm
Wheelbase 2615mm
Chassis & Body
Curb Weight 1430kg
Engine
Redline 8,000 RPM
Performance
0-100 4.7 seconds
0-400m 12.9 seconds
Dimentions
Length 4640 mm
Width 1720 mm
Height 1340 mm
Wheelbase 2720 mm
Chassis & Body
Curb Weight 1360 KG
Wheels 16 x 6.5
Engine
Displacement 2498
Redline 7,000 RPM
Performance
0-100 6.18 seconds
0-400m 14.4 seconds
Dimentions
Length 4675mm
Width 1780mm
Height 1360mm
Wheelbase 2720mm
Chassis & Body
Curb Weight 1530kg
Engine
Redline 8,000 RPM
Performance
0-100 5 seconds
0-400m 13.1 seconds
Dimentions
Length 4580 mm
Width 1725 mm
Height 1340 mm
Wheelbase 2665 mm
Chassis & Body
Curb Weight 1410 Kg
Wheels 17 x 7.5
Tyres 225/45
Engine
Displacement 2498
Redline 7,000 RPM
Performance
0-100 6.2 seconds
0-400m 14.3 seconds
Dimentions
Length 4600mm
Width 1785mm
Height 1360mm
Wheelbase 2665mm
Chassis & Body
Curb Weight 1540kg
Engine
Redline 8,000 RPM
Performance
0-100 4.9 seconds
0-400m 12.9 seconds
Views 576
22-12-2018, 08:28 AM
Views 1,868
19-11-2017, 08:21 PM
Last Post by Bandit
Views 633
19-11-2017, 10:00 AM
Views 1,014
25-09-2017, 07:47 PM
Last Post by russelllinn
Views 740
22-09-2017, 06:39 PM
