JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Will 9.5j and 8.5j wheels fit???
Chri5
03-01-2018, 10:44 AM
I just got a set of wheels that are 8.5 and 9.5j wide with 235/45/17 tyres and 255/40/17 tyres.
The car is on standard suspension with the intention of dropping it soon.
Will these go on without modification or will I need arches rolling to accomadate???
The car is a 1999 altezza rs200 Smile
thanx in advance
chris
Chri5
03-01-2018, 10:44 AM #1
thanx in advance
chris
03-01-2018, 11:12 AM
I know Wozza has 255's on his motor with 18" alloys and lowered but has had his arches rolled? think it'll depend on the offset of the wheels mate,
Some of the wheel/tyre combination's that can fit?
Standard wheels ....PCD = 114.3mm Offset = 50mm
Standard Rim f/r = 17"x7"
Standard Tyre f/r = 215/45-17
(A -40mm drop is possible with this combination)
18" upgrade f/r =18"x7 1/2"
18" upgrade f/r =225/40/18
18" upgrade f/r =18"x8"
18" upgrade r =18"x8.5"
18" upgrade r =255/35-18
(A -30mm drop is possible with these combination's, however minor arch rolling is needed with the 255/35 combination)
19" upgrade f/r =19"x8"
19" upgrade f/r = 235/35-19
(A -25mm drop is possible with these combination's)
With 19's don't run any rim bigger than 8" on the front as it will hit the strut.19's will rub on the front inner arch at full lock, but this can be solved by cutting or bending away some of the plastic trim
OFFSETS
FRONT
width | offset | tires range (width)
7 = 40 and up 215-225
7.5 = 42 and up 215-235
8 = 43 and up 215-235
8.5 = 45 and up 215-225
REAR
7.5 = 40 and up 215-235
8 = 42 and up 215-245
8.5 = 45 and up 225-265 (255-265 requires rolling or having lip)
9 = 49 and up 235-275 (MAY require rolling or shaving lip)
9.5 = 52 and up 245-285 (MAY require rolling or shaving lip, 285 may require more modification)
10 = 45 and up 255-315(requires pulling fender)
Also an OFFSET calculator here so you can see what the difference is between standard fit and aftermarket [URL="http://www.1010tires.com/WheelOffsetCalculator.asp"]OFFSET CALCULATOR CLICK HERE?
[/URL]
Edited 14-02-2010, 09:20 PM by Bandit.
03-01-2018, 11:12 AM #2
OFFSETS
FRONT
REAR
[/URL]
03-01-2018, 12:44 PM
also your keeping the small 17's so i don't think you'll have any problems.(depending on offset as bandit say's)
03-01-2018, 12:44 PM #3
Fry-Up
03-01-2018, 01:39 PM
just out of interest if I want to go up but I don't want my arches rolled, can I get 19's? if so, what offset and width is safe? if I can't get 19's without rolling arches, What offset and width should I be looking for on 18's
also, whats the offset of the stock 17's?
Fry-Up
03-01-2018, 01:39 PM #4
Fry-Up
03-01-2018, 03:23 PM
o yeh, cheers
Fry-Up
03-01-2018, 03:23 PM #5
o yeh, cheers
Chri5
03-01-2018, 05:27 PM
Well if I need arches rolling then fair enough.
Think it's only about £80 for the rears from arhenemies.
If it needs more then I'll look into it before deciding.
Iirc the offset is 38 and 35 but will double check when I go outside next Smile
Chri5
03-01-2018, 05:27 PM #6
03-01-2018, 05:33 PM
Yeah they did my arches for me, and did a great job !!
Get yourself a set of 19"
03-01-2018, 05:33 PM #7
03-01-2018, 05:46 PM
isnt 19 a overkill on a lexus?
03-01-2018, 05:46 PM #8
03-01-2018, 05:49 PM
Wait till you see my one mate , just ask some of the guys who have seen my car if its overkill or not. You should start a poll :lol: to find out
03-01-2018, 05:49 PM #9
03-01-2018, 06:40 PM
i wish i had 19's they look good on moleys!!still like my 18's though
03-01-2018, 06:40 PM #10
Views 583
11-03-2021, 02:23 PM
Last Post by Chris0121
Replies 18
Views 1,287
27-01-2021, 07:29 AM
Views 1,242
21-09-2020, 06:00 PM
Last Post by paddywak
Views 784
06-05-2020, 06:46 AM
Last Post by ISCal
Views 702
05-03-2020, 09:15 AM
Last Post by JonPowellDJ
Views 505
03-01-2020, 06:36 PM
Last Post by Bandit
Views 1,713
03-09-2019, 06:27 AM
Last Post by Stoney
Views 823
07-08-2019, 03:50 PM
Last Post by jasons
