JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security speaker size in 200 SE
11-01-2018, 05:18 PM
hi all
i want to upgrade my front door speakers but not sure what the size is for them
anybody with the answer
thanks
11-01-2018, 05:18 PM #1
hi all
thanks
11-01-2018, 05:21 PM
6.5" (17cm)
You need an 18mm MDF spacer to fit after market ones though.
11-01-2018, 05:21 PM #2
6.5" (17cm)
11-01-2018, 05:24 PM
cool thanks 2tongues
at least i no now so i can look at doing that at some stage
11-01-2018, 05:24 PM #3
JeffMcC
Hope this helps
woofer diameter: 6 1/2"(165mm)
mounting depth woofer: 2 7/16" (63mm)
mounting hole diameter woofer: 4 15/16" (125mm)
tweeter diameter: 1"
mounting depth tweeter: 3/4" (19mm)
mounting hole diameter tweeter: 1 7/8" (48mm) :thumbup1:
JeffMcC
11-01-2018, 05:24 PM #4
Hope this helps
11-01-2018, 05:35 PM
cheers all for the replies
11-01-2018, 05:35 PM #5
13-01-2018, 06:10 PM
what size should they be ive seen afew some 12mm and some 18mm deep
http://cgi.ebay.co.uk/Pair-of-6-5-16-5-1...230119669e
here are they 12mm ones would they work
Edited 25-02-2010, 03:28 AM by DJW.
13-01-2018, 06:10 PM #6
13-01-2018, 06:30 PM
Link wont work matey
13-01-2018, 06:30 PM #7
13-01-2018, 06:31 PM
Ah, I found problem, one too many http:// so take it out when u put it into browser guys Big Grin
13-01-2018, 06:31 PM #8
14-01-2018, 05:32 AM
sorry my mistake gents
thanks for the edit wozza
14-01-2018, 05:32 AM #9
joanalex
01-02-2018, 02:17 AM
It should be worked.If you get the ones with the external cross-overs, you will have to experiment to see if they are needed and whether they sound better than just utilizing the internal amp low pass filter.I looked for mid bass only that were in the range of the speakers you linked to.I have the Audiobahn and like them plenty.The MA Audio and the Pyle Dryver look like bargains.All three are less than the $109.00 price of the JBL's you linked to.
dsi
joanalex
01-02-2018, 02:17 AM #10
dsi
Views 1,039
22-07-2019, 05:08 PM
Replies 27
Views 4,799
21-06-2019, 10:08 AM
Last Post by FunkMasterJay
Views 1,736
18-06-2019, 06:12 PM
