JapCarForum General Discussions The JCF Lounge Log manifold pros and cons?
16-01-2018, 04:54 PM
hi there,
need to get new manifold made for the v8 as the ones now are in bad state. i was thinking about log manifolds as they wont take up as much space so was wondering if any one knows the pros and cons?
thanks
16-01-2018, 04:54 PM #1
hi there,
thanks
16-01-2018, 05:01 PM
http://www.examiner.com/x-26210-Raleigh-...t-II-of-II
16-01-2018, 05:05 PM
i like the tubular manifold but theres just not enough space to make a good decent one.
16-01-2018, 05:05 PM #3
16-01-2018, 05:09 PM
Tubular manifolds are better if you can fit them in. But a log manifold will probably be cheaper, easier to make and stronger.
16-01-2018, 05:09 PM #4
16-01-2018, 05:32 PM
yeah a good designed tubular manfold is a lot better than a log one but its just the space mate so i am thinking to go for log manifold because marcus got manifolds from america and it will take 2-3 weeks before i get them.
16-01-2018, 05:32 PM #5
16-01-2018, 06:51 PM
Asi yeah a good designed tubular manfold is a lot better than a log one but its just the space mate so i am thinking to go for log manifold because marcus got manifolds from america and it will take 2-3 weeks before i get them.
What is wrong with the one that was on the car when you got it :confused::confused:
16-01-2018, 06:51 PM #6
17-01-2018, 03:18 PM
one of them are dented and has bad weld on it so it needs to be replaced or the car will lose power
17-01-2018, 03:18 PM #7
17-01-2018, 05:10 PM
Just re-weld the so called bad weld
17-01-2018, 05:10 PM #8
17-01-2018, 05:22 PM
and you can pull the dent out as well surely>?
17-01-2018, 05:22 PM #9
17-01-2018, 05:54 PM
well yeah but its been dented to fit....
17-01-2018, 05:54 PM #10
