JapCarForum Car Manufacturers Lexus/Toyota led scuff plates group buy
08-02-2018, 06:40 PM
so i'm now taking orders for the group buy on these.
you will get a front set of laser cut plates produced from 4mm 5083 Ally Sheet with the words lexus cut in them with holes made in the back for oem fitting and pollished surface finish, 2 water proof sealed led light strips color of your choice ready fitted into plate and 2 power inverters with conectors for the led strip this means you can order other colors and change in minutes.you will need to conect them to the courtesy light loom found in the key barrel. included with be fitting instruction and links to a how to video i will post.
these will fit the is200/300 oem fittings but can be fitted to other lexus cars with the use of double sided tape which can be done for you for no extra cost
the reason i did these is because the oem units from lexus have had so many problems with the light units and the cost was over 200 pounds.
i will only be doing 40 sets and this will be a one off order so if you miss it then i wont be doing it again as the cost of doing this is quite high, i will be posting these on on the lexus owners club and the is forum in the usa.
so prices are as follow.
paid up members will be 125 pounds posted to your door
none paid up members and guests will be 135 pounds posted to you door
i will be taking a 50 pound deposit with you order and delivery time will be around 6 weeks
colors to choose from are these. the color seen is what you will get
[Image: led.jpg]
please state what color you would like when ordering.
red
white
blue
green
yellow
you can send your deposits via paypal to the address below and each unit sold will have a normal 1 year guarantee and money made from these will go to the club for other uses
[email protected]
thanks guys for all the help with this....
jay
08-02-2018, 06:40 PM #1
[Image: led.jpg]
red
white
blue
green
yellow
[email protected]
jay
09-02-2018, 08:41 AM
no mate i have to order 80 units before he will set the laser cutter up but if your not happy ones the plates are here with me and i have posted up photo's then you can have your money back.... but i dont think you will be unhappy. has taken me a long time to get this right.
09-02-2018, 08:41 AM #2
TM
09-02-2018, 09:33 AM
:thumbup1:i know u said it will fit other lexus,but can u make sure they will fit a GS and the newIS250 ,coz i'm interested :thumbup:
thinking the white,and blue looks good:thumbup:
TM
09-02-2018, 09:33 AM #3
09-02-2018, 11:18 AM
sure mate. they are the same size as the oem units and they should fix as standard to all lexus as the doors are all about the same size but i will check out the size for you and post it up here
09-02-2018, 11:18 AM #4
09-02-2018, 03:34 PM
how much are the genuine lexus illumated ones
09-02-2018, 03:34 PM #5
09-02-2018, 04:17 PM
about 250
09-02-2018, 04:17 PM #6
about 250
09-02-2018, 04:24 PM
hmm sounds tempting. always wanted them
09-02-2018, 04:24 PM #7
09-02-2018, 05:28 PM
i thought the newer ones didnt break as the old ones. or thats not the case
09-02-2018, 05:28 PM #8
09-02-2018, 05:51 PM
i heard so much about them thats why i want for custom made units instead.....
09-02-2018, 05:51 PM #9
09-02-2018, 05:53 PM
might give them a miss
09-02-2018, 05:53 PM #10
 3 Guest(s)
 3 Guest(s)
