JapCarForum General Discussions The JCF Lounge Toyota Engine Codes
Toyota Engine Codes
Toyota Engine Codes
15-02-2018, 03:01 PM
I have a list of toyota engine codes here guys.
The first numeric characters specify the engine block's generation
The next one or two letters specify the engine family
The suffix (separated by a dash) specifies the features of the engine:
A Valvematic variable lift intake head
B Twin SU-style side-draft carburetors
After 2000 indicates E85 Ethanol fuel.[citation needed]
C Carburated / California Emissions Controlled
D Twin Downdraft carburetors
E Electronic Fuel injection
F Economy narrow-angle valve DOHC
G Performance wide-angle valve DOHC
H High compression like 9.8:1 (example: 5E-FHE)
High pressure charged (example: 2L-THE)
I Single-point fuel injection
J Autochoke (Early models) or unknown pollution control
L Transverse
M Philippines' market (meaning unknown)
N CNG fuel
P LPG fuel
R Low Compression (For 87 and below octane fuel)
S Swirl intake (1980s)
SE Direct injection (1990s)
T Turbocharged
U With Catalytic converter Japan-spec emissions
V Common Rail Diesel Injection (D-4D)
X Atkinson cycle (typically also indicates a Hybrid engine, as Toyota only uses the Atkinson cycle with hybrids)
Z Supercharged
so a 1G-FE would represent first generation, with the family G, then it is narrow angled valves and electronically injected.
For asi it qould be 1st generation, UZ family, narrow angled valves and electronically injected fuel. (1uzfe)
For stav it would be 1st generation, G family wide angle valves, turbocharged and then electrionically fuel injected.
Hope this helps anyone
Dont forget to rep Wink
Edited 29-03-2010, 07:03 PM by Dark Samurai.
15-02-2018, 03:01 PM #1
L Transverse
N CNG fuel
P LPG fuel
T Turbocharged
Z Supercharged
15-02-2018, 03:17 PM
Nicked from Wiki pedia? lol
15-02-2018, 03:17 PM #2
15-02-2018, 03:19 PM
slightly lol
and if anyone needs it, they maybe may not look to wiki, but now its on here
15-02-2018, 03:19 PM #3
slightly lol
15-02-2018, 03:22 PM
Dark Samurai Dont forget to rep Wink
Do we give rep for copy-and-paste jobs from Wikipedia then ? :lol:
P.S. You forgot to remove the "citation needed" text :laugh:
Edited 29-03-2010, 07:09 PM by steviewevie.
15-02-2018, 03:22 PM #4
15-02-2018, 03:23 PM
ok delete the thread then lol
15-02-2018, 03:23 PM #5
15-02-2018, 03:44 PM
lol no its a good idea mate
15-02-2018, 03:44 PM #6
Views 723
15-07-2021, 05:39 PM
Last Post by Mrs HollowPoint
Views 1,272
01-05-2021, 04:40 AM
Views 1,436
01-01-2020, 01:18 PM
Last Post by MrGash
Views 1,368
22-10-2019, 03:31 PM
Replies 18
Views 2,867
10-06-2019, 04:43 AM
Last Post by Phil01
Views 677
08-06-2019, 07:31 AM
Last Post by BOOSST
