JapCarForum General Discussions The JCF Lounge fault code
fault code
fault code
Mikey
16-02-2018, 07:37 AM
Had the engine light come on yesterday with flashing trc got the code read roud the corner at nates garage it came up
1635523933.0 type 7001
ive tried google but not come up with anything
mike
Mikey
16-02-2018, 07:37 AM #1
mike
On what car, an IS200 ?
16-02-2018, 07:37 AM #2
16-02-2018, 07:53 AM
Assuming it is an IS200, what sort of code reader was used ? That doesn't sound like a normal OBD-II code, it should be something like Pxxxx.
Does the car seem down on power/mis-firing ?
Which TRC light is flashing, is it the one with the pic of the car skidding, or the "TRC OFF" light ? Could be a coil pack.
16-02-2018, 07:53 AM #3
Mikey
16-02-2018, 08:37 AM
yep is200 car is running fine it was a bosch machine so not sure
it was the TRC OFF
Mikey
16-02-2018, 08:37 AM #4
it was the TRC OFF
16-02-2018, 09:00 AM
If it is a coil pack, it can be harder to notice on the IS200 given it's a 6-cylinder engine and is very smooth.
You could do with trying to get the proper OBD-II fault code though. Presumably the engine management light is on ?
TRC OFF flashing shows there's a problem with the TRC area. But this can be caused by a coil pack too.
16-02-2018, 09:00 AM #5
Mikey
16-02-2018, 09:15 AM
ok mate its gone now i want to get an obd2 scanner my self which one would you recomend i was looking at the elm327 linky
Mikey
16-02-2018, 09:15 AM #6
16-02-2018, 09:32 AM
I've got a standalone reader since I don't have a laptop. Some of the other guys will be able to help you out with USB cables etc.
16-02-2018, 09:32 AM #7
Mikey
16-02-2018, 09:42 AM
cheers mate
Mikey
16-02-2018, 09:42 AM #8
cheers mate
16-02-2018, 09:43 AM
Especially if it's intermittent, I think it's quite likely to be a coil pack. You'll need the codes though to confirm that and to start narrowing down which one it is, if that is indeed the problem. An actual TRC/ABS problem is possible though less likely IMHO.
16-02-2018, 09:43 AM #9
Views 611
04-06-2019, 04:48 AM
Views 2,143
09-11-2018, 06:56 PM
Views 3,308
27-04-2018, 09:10 AM
Last Post by Carpediem
Views 593
13-08-2017, 09:41 AM
