JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Lexus IS200 TTE Red Arbs
06-05-2018, 04:57 PM
Ok I'm finally getting my rear arb fitted tomorrow :thumbup::thumbup:
I'm just wanting to know what difference if any there will be by using the different holes, ie what handling & ride quality differences will there be .
Cheers Moley
06-05-2018, 04:57 PM #1
Cheers Moley
06-05-2018, 05:04 PM
Finally you decided to fit your ARB's. It was about time mate.
06-05-2018, 05:04 PM #2
06-05-2018, 06:22 PM
Come on guys no one got an opinion on this ???
06-05-2018, 06:22 PM #3
Fozzy
06-05-2018, 06:43 PM
The holes further out will provide a slightly softer setting, allowing a little more roll and a bit more compliance over bumps. To be honest your best bet is to set it on the harder setting and go for a ride. If you find it acceptable then stick with it. If you find its too harsh the change it to the softer setting. Its very quick to change from one to the other
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
06-05-2018, 06:43 PM #4
06-05-2018, 06:49 PM
Ok that sounds like a good plan :thumbup1:
06-05-2018, 06:49 PM #5
06-05-2018, 08:11 PM
as said moving the link to the furthest out hole makes no diff......the holes were put their so you could put the anti roll bar link as straight as you could,it depends how low you are to what hole you use, if they are at an angle they can bend very easy..tony at wim has also explained this.......
06-05-2018, 08:11 PM #6
Ally
07-05-2018, 03:07 AM
Moley, are you replacing the drop links as well, or are you just hoping to stick to the originals? I got a quote from Lexus yesterday of £194.58 all in for front and rears.....and that was with my discount :ohmy:. Looked on ebay and you can get all 4 for about £60, but they are made in Thailand, so could potentially be turkish delight.
JDM black headlights, rear fog light conversion, JDM size number plates, JDM rear number plate garnish, JDM dash tray, wind deflectors, TRD body kit, white TRD gearknob, TTE lowering springs, TTE ARB's, K&N air filter, stainless steel A/C rings, stainless clock cover, radiator cooling panel, LED side light bulbs, blue reversing bulbs, fan washer jets, clear side repeaters, PIAA silicone wipers, Alpine IDA-X200 headunit, 17 x 8 et40 OZ Ultraleggera with 225/45/17 Toyo Proxes T-1R
Ally
07-05-2018, 03:07 AM #7
edeath
07-05-2018, 03:39 AM
Bought some droplinks on ebay for about £25 for the fronts and they are fine. Made in Korea but fine.
edeath
07-05-2018, 03:39 AM #8
07-05-2018, 09:15 AM
Well my front arb is fitted already and I've have got new drop links for the rear, but will see if I can get the arb fitted without changing the drop links, and if I can they will be up for sale Huh
07-05-2018, 09:15 AM #9
fil4362
08-08-2018, 11:58 AM
just been told of a group buy on roll bars. Any idea whats happening with it, I just came over from LOC where no one seems to know anything abotugetting any.
fil4362
08-08-2018, 11:58 AM #10
Views 497
16-06-2023, 09:40 AM
Views 1,409
10-11-2020, 07:29 AM
Views 712
09-08-2020, 04:24 PM
Views 1,206
18-06-2020, 04:50 PM
Last Post by Mr Reman
Views 710
05-03-2020, 06:08 PM
Views 384
05-03-2020, 05:28 PM
Last Post by spikes
Views 1,305
10-02-2020, 11:08 PM
Last Post by ormi
Replies 25
Views 3,544
27-04-2019, 06:43 PM
Last Post by FunkMasterJay
Views 1,867
14-04-2019, 07:33 PM
Last Post by Dark Samurai
