JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Lexus is200 Upper Suspension arm prices?
Pages (3): 1 2 3 Next
19-05-2018, 10:40 AM
Well just back from the MOT and apart from failing on a few wee bulbs the only main thing was the front upper suspension arm Sad
Anyone know of hand the price of these and where to source?
Cheers
Todd
Toyota Altezza Z Edition.
19-05-2018, 10:40 AM #1
Cheers
Todd
19-05-2018, 11:37 AM
you checked toyo-diy mate? Best thing to do is have a look on Toyo-Diy and then speak to your local toyota garage and get a price from them
19-05-2018, 11:37 AM #2
19-05-2018, 12:29 PM
Thanks mate, the fitting isn't an issue but given the lexus part is pretty expensive, just wanted to see if anyone new where one could be obtained cheaper.
Ta
Todd
19-05-2018, 12:29 PM #3
Ta
Todd
19-05-2018, 12:56 PM
Toyo diy is of limited use now that it's got no diagrams on it!
Christ, that is quite an expensive part, wonder how you managed to bend that! My list price here is about £230. The only saving grace to that is that it includes everything you need to fit it, i.e. new nuts, split pins etc.
19-05-2018, 12:56 PM #4
19-05-2018, 12:57 PM
I suppose your only advantage is that the part is the same on all altezza's, is200, is300 etc. so you could get one from a breakers.
19-05-2018, 12:57 PM #5
19-05-2018, 02:14 PM
Not bent mate, well don't think so LOL
Fail sheet just stated it had excessive play in front upper suspension ball joint.
19-05-2018, 02:14 PM #6
19-05-2018, 02:16 PM
Oh yeah duh, they're a single part with integral balljoint aren't they... forgot that!
19-05-2018, 02:16 PM #7
19-05-2018, 02:20 PM
Local partco is doing them for 150 (blueprint) or they have their own ones for about £80 but not in stock in the UK, booo
19-05-2018, 02:20 PM #8
TommyH
19-05-2018, 02:51 PM
Which arm is it, does anyone have a pic ?
TommyH
19-05-2018, 02:51 PM #9
19-05-2018, 03:13 PM
It's at the top of the front suspension, horseshoe shaped with a balljoint in the middle. Don't have a pic I'm afraid!
19-05-2018, 03:13 PM #10
Views 492
16-06-2023, 09:40 AM
Views 547
03-11-2021, 01:16 PM
Last Post by argyle dan
Views 1,406
10-11-2020, 07:29 AM
Views 707
09-08-2020, 04:24 PM
Views 1,203
18-06-2020, 04:50 PM
Last Post by Mr Reman
Views 740
06-04-2020, 02:52 PM
Views 709
05-03-2020, 06:08 PM
Views 382
05-03-2020, 05:28 PM
Last Post by spikes
Views 1,305
10-02-2020, 11:08 PM
Last Post by ormi
