JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Grom ipod
Grom ipod
Grom ipod
TimmyK
30-06-2018, 06:21 AM
Are the Grom Ipod adapters any good?
Car 1 - 02 Lexus IS200 SE Strathcaron Blue, Sport Grille, TTE Lowering Springs (to be fitted), K&N Panel Filter, 6500K XENON Headlight Main & Dipped Bulbs, Xenon Sidelights, 17" Gunmetal Powder Coated Alloys, Front Grooved Discs and Mintex Pads
Car 2 - 73 Hillman Imp AKA Hilda, Aquarious Blue, work in progress!
TimmyK
30-06-2018, 06:21 AM #1
kam05
30-06-2018, 06:27 AM
Well, if you want to hook up your ipod to the factory headunit, then yeah they are good.
kam05
30-06-2018, 06:27 AM #2
30-06-2018, 06:39 AM
yeap very good, as long as you get the ipod interface version, the headphone jack ones loose sound quality apparently
30-06-2018, 06:39 AM #3
TimmyK
30-06-2018, 06:40 AM
They easy to fit? How hard is removing the head unit?
TimmyK
30-06-2018, 06:40 AM #4
30-06-2018, 06:41 AM
its about 30-60 mins job, very easy mate, there are plenty of walk throughs around:thumbup1:
30-06-2018, 06:41 AM #5
30-06-2018, 06:51 AM
SHAHZ yeap very good, as long as you get the ipod interface version, the headphone jack ones loose sound quality apparently
Do they? I've got the aux and it's fine for the minute, hope that continues! :thumbup1:
SHAHZ its about 30-60 mins job, very easy mate, there are plenty of walk throughs around:thumbup1:
Yep very simple, it was just 4 bolts and 2 screws to get my dash apart - in fact I spent more time just masking the dash to prevent scratching it (which you HAVE to do) than actually taking it apart.
A lot of us on here have done it before so there's plenty of advice available should you need it Smile
30-06-2018, 06:51 AM #6
TimmyK
30-06-2018, 07:11 AM
Couldnt find a walkthrough on here. Is it worth buying a used one and saving £40?
TimmyK
30-06-2018, 07:11 AM #7
We can take our dash out in less that ten minutes, you slide the top panel off (where the little piece of fabric is(but sometimes under the fabric there are two screws, undo these))
Then slide out the bottom panel (the heated seats, and trc and snow button panel)
Unclip the wires from the buttons to make work easier.
You should see 2 bolts above the A/C unit when top panel is taken off, undo these.
You should also see 2 bolts under the headunit when bottom panel is taken on, undo these.
Now lift both the units up a couple of centimetres, now pull the whole thing forward, and it should come out. Now just located the wire you have to put GROM into, then put it all back together.
30-06-2018, 07:11 AM #8
30-06-2018, 07:18 AM
parthiban Do they? I've got the aux and it's fine for the minute, hope that continues! :thumbup1:
QUOTE]
I was under the impression the some said there was a loss of sound quality, but i could be wrong as i thought you where one of them:Fish:Rolleyes
[quote=parthiban]Yep very simple, it was just 4 bolts and 2 screws to get my dash apart - in fact I spent more time just masking the dash to prevent scratching it (which you HAVE to do) than actually taking it apart.
Yeap taping up the dash is the longest bit, dont think i actually removed the headunit, just the bottom bolts and the dash tray, which gave enough room to feel your way to the back of the HU, THIS shows where my unit sat before i removed it
30-06-2018, 07:18 AM #9
QUOTE]
30-06-2018, 07:39 AM
SHAHZ I was under the impression the some said there was a loss of sound quality, but i could be wrong as i thought you where one of them:Fish:Rolleyes
Nah that wasn't me, I was the one complaining that the iPod has c**p sound quality :Fish:
30-06-2018, 07:39 AM #10
Views 1,074
14-07-2019, 05:06 PM
Last Post by Stoney
xcarlink or grom
by lexynik
Views 975
18-02-2018, 08:33 PM
Last Post by Dannymo
