JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza IS200 Brake Caliper repair kit
wahidhussain
20-09-2018, 09:07 PM
hi all
has anyone tryed this http://cgi.ebay.co.uk/Lexus-IS200-Brake-...3efe8d4c03 Brake Caliper repair kit? does it work?
thanks
wahid
wahidhussain
20-09-2018, 09:07 PM #1
hi all
thanks
wahid
21-09-2018, 04:35 AM
You can buy brake servicing kits from Toyota too. That one just has the rubber bits to replace on your calipers. So it might help, but if you've got a problem with your calipers it depends on exactly what the problem is - e.g. if the pistons are in a bad way then it's not going to help.
You can also find new/refurbished calipers on eBay, but similarly you need to check exactly what's included - again the pistons may often be not included.
I'm not trying to say it's always the pistons that are the problem, just that it depends on what you need to fix/replace.
What problem have you got ?
21-09-2018, 04:35 AM #2
Fozzy
21-09-2018, 07:24 AM
I agree with stevie here. Having done a few caliper refurbs, i can say its certainly not worth the extra cost of getting the seal kits from lexus/toyota (they are extortionate)
The main problem with these types of calipers is they collect a small amount of water in between the piston and the caliper body. This will cause the pistons to go rusty and seize in place. When this happens it is best to replace the pistons with new ones. They are about £16 each.
I have experienced refurbing my own calipers, which lasted 4 months before seizing again because i didnt replace the pistons.
It is quite an involved job and can be fiddly getting the seals back in place. I would reccomend replacing the caliper with either a refurbed item or new, if it has seized.
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
21-09-2018, 07:24 AM #3
Fozzy
21-09-2018, 07:09 PM
Uneven wearing would suggest sticky pistons or sliders. Changing the calipers can be tricky. if someone is making up adaptro brackets its straight forward, but if you have to sort it out yourself it can be a pain
Fozzy
21-09-2018, 07:09 PM #4
wahidhussain
21-09-2018, 07:12 PM
steviewevie You can buy brake servicing kits from Toyota too. That one just has the rubber bits to replace on your calipers. So it might help, but if you've got a problem with your calipers it depends on exactly what the problem is - e.g. if the pistons are in a bad way then it's not going to help.
thanks for the reply guys
the problem i have is the front passanger side
well i think its the caliper i have't open the caliper but when i turn the wheel its a bit hard to turn and the rest move freely
wahid
Marsdendean Is it cost effective to change the brakes like some people are doing to the LS400 ones??? I think one of mine is sticking, or have a bad problem as my old pads were worn un evenly??
wahidhussain
21-09-2018, 07:12 PM #5
wahid
wahidhussain
21-09-2018, 07:23 PM
Hurricane Uneven wearing would suggest sticky pistons or sliders. Changing the calipers can be tricky. if someone is making up adaptro brackets its straight forward, but if you have to sort it out yourself it can be a pain
i was thinking of going to indi Garage to sort it out
thanks
wahidhussain
21-09-2018, 07:23 PM #6
thanks
22-09-2018, 05:01 AM
wahidhussain the problem i have is the front passanger side
That does sound like the caliper is sticking, which is a fairly common problem.
Quote: was thinking of going to indi Garage to sort it out
Be aware of getting them to do the job fully, e.g. replacing the pistons if necessary as Hurricane has said. Otherwise it might fix it for a bit but the problem then soon comes back again. See what they'll quote you.
22-09-2018, 05:01 AM #7
22-09-2018, 06:07 AM
if it helps i have a set of calipers that will be coming off my car very soon, they were recently refurbished and the pistons seemed it very good working order they were cleaned up and re housed by Hurricane
22-09-2018, 06:07 AM #8
22-09-2018, 03:10 PM
Marsdendean Would it be possible for a group buy on some adapters, or get some made if a few people are looking to upgrade there brakes??
Anything's possible if enough people want to make it happen ! :biggrin:
22-09-2018, 03:10 PM #9
reganlives
20-01-2020, 06:34 PM
Sorry to revive an old thread but I need help guys! I've just put my car back on the road after a month and I think the right hand caliper is seized. I was driving and the car started vibrating really badly as though the wheels were off balance or loose but after checking the wheels I noticed the front right to be warm. Anyway, its getting quite hot and I sprayed a bit of water on it to see just how hot and it burnt away straight away from the brakes. The front left is ok so guess I need to get the right caliper repaired or replaced? I need advice asap please as the car is due its mot tomorrow and I need the car on the road. Do I need a complete recon with piston or just the seals/sliders etc? I dont know how to do it myself so would have to get my mechanic to do it.
Where should I get the kit from as well if needed? If possible then I dont want to go for any other make other than blueprint as I trust their stuff for copy parts.....
Thanks in advance guys...
reganlives
20-01-2020, 06:34 PM #10
Views 799
12-12-2024, 07:55 PM
Views 874
08-11-2024, 09:35 AM
Last Post by Dinho
Views 1,835
06-11-2023, 07:38 AM
Views 3,953
02-11-2023, 04:43 PM
Views 651
06-08-2023, 05:47 PM
Last Post by Brad92
Replies 38
Views 3,420
23-02-2023, 07:09 PM
Views 671
18-10-2022, 07:53 AM
Views 1,048
03-09-2022, 04:53 PM
Views 797
29-08-2022, 03:48 PM
Replies 35
Views 9,829
04-08-2022, 10:23 AM
Last Post by cjoseph
