JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Where to find this bush? :(
lex2oos
30-09-2018, 07:57 PM
Helllo!
I am having knocking sound from cars suspension a while now. and today I think I found from where it is coming from.
It is in rear, and both sides are kinda loose. I could make the knocking sound by moving the wheel up and down by hand
red circle shows which bush it is
[Image: file.php?id=586]
I see that dealer dont sell them seperate.
thanks Smile
lex2oos
30-09-2018, 07:57 PM #1
Helllo!
thanks Smile
Fozzy
01-10-2018, 06:40 AM
You cant get them seperately, you have to replace the entire hub
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
01-10-2018, 06:40 AM #2
01-10-2018, 03:02 PM
Although the dealers don't sell them separately, people have had luck in the past gvetting these sort of bushes from bush specialists, as I recall. If you can fine the dimensions of the bush you might be able to move that forward ? Let us know how you get on.
01-10-2018, 03:02 PM #3
TommyH
01-10-2018, 03:56 PM
Try this guy http://cgi.ebay.co.uk/REAR-BUSHES-LEXUS-...2c588aa6b3
TommyH
01-10-2018, 03:56 PM #4
iano21
02-10-2018, 03:44 PM
well if you look back to threads i looked and found this lad in ireland. bushings are really good quality and value. i put two in my car
http://shop.ebay.ie/?_from=R40&_trks...s200+rear+bush
ian
iano21
02-10-2018, 03:44 PM #5
ian
lex2oos
03-10-2018, 04:01 PM
nice, thanks!
I know a guy from car parts store. myb will go hunting in his warehouse Smile
lex2oos
03-10-2018, 04:01 PM #7
nice, thanks!
iano21
04-10-2018, 04:37 PM
make sure and get it exact cause it a swivel bushing, have not seen them in many cars that size but you could be lucky Big Grin
iano21
04-10-2018, 04:37 PM #8
