JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission HKS FCD in a non turbo engine
Carles
26-11-2018, 07:55 PM
Hi, I want to run my IS200 auto with E85 then I need to increase the AFR.
Just bought a HKS FCD but I discovered later that it is for use in turbo engines, could use it safely in an aspirated engine?
Carles
26-11-2018, 07:55 PM #1
mplavery
26-11-2018, 08:01 PM
Carles Hi, I want to run my IS200 auto with E85 then I need to increase the AFR.
No matey, cant use it on a non turbo car
The FCD simply modifies the TPS voltage signal 'fooling' the ECU into thinking that boost levels are lower than they actually are, thus preventing fuel cut. The FCD monitors the voltage signal and, once it has reached the level set by the adjuster, the voltage is 'clamped' so that it does not rise any higher. Providing the FCD is adjusted to a voltage level slightly below the ECU fuel cut point, the FCD will prevent the ECU from ever cutting fuel. This will allow the boost level to be increased to any desired level - subject to fuelling, turbocharger and engine limits.
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
26-11-2018, 08:01 PM #2
[/COLOR]
[/COLOR]
26-11-2018, 08:02 PM
it's more for a supercharger than a turbo. thing if you going to use e85 you will need a good garage to get you running. might have to change injectors
26-11-2018, 08:02 PM #3
Carles
26-11-2018, 08:28 PM
Thanks mate.
I bought too a kit to use E85 but don't work properly. I thought that the FCD would be the solution but looking the assembly instructions suspected that it was not.
Now I can run with 60% of E85 with no problem and no MIL but I want to run with 100% E85.
I think the size of the injectors of IS200 it's 243 cc, do you know what the next size and the model compatible with the 1g-fe engine?
Carles
26-11-2018, 08:28 PM #4
Thanks mate.
26-11-2018, 08:47 PM
also pure e85 can damage fuel lines....
26-11-2018, 08:47 PM #5
26-11-2018, 09:00 PM
mplavery No matey, cant use it on a non turbo car
Not quite, youve described a Greddy BCC there.
The FCD works differently and more dangerously, it cuts the voltage by a percentage right through the range so leans you out right through, not just at the top like the BCC
26-11-2018, 09:00 PM #6
26-11-2018, 09:07 PM
You can use blackbox by TTE, but their reliability issues are not worth it mate.
26-11-2018, 09:07 PM #7
27-11-2018, 08:13 AM
The Greddy BCC is the better option.
27-11-2018, 08:13 AM #8
mplavery
27-11-2018, 09:03 AM
Sparkystav Not quite, youve described a Greddy BCC there.
Oh right, yes maybe i am, Am i right in saying on the BCC you can increase the fuel cut using these, although its not recommended
[/COLOR]
[/COLOR]
mplavery
27-11-2018, 09:03 AM #9
[/COLOR]
[/COLOR]
27-11-2018, 11:25 AM
mplavery Oh right, yes maybe i am, Am i right in saying on the BCC you can increase the fuel cut using these, although its not recommended
With the BCC you can adjust where the clamp voltage is, FYI most cars are around 4.3v
27-11-2018, 11:25 AM #10
Views 416
15-04-2023, 09:06 AM
Views 563
15-01-2023, 08:08 AM
Views 1,098
17-08-2022, 09:38 AM
Last Post by mattlaw
Views 658
23-04-2021, 03:50 AM
Last Post by S
Views 967
01-04-2021, 08:42 AM
Views 443
10-03-2021, 05:19 AM
Views 1,175
14-11-2020, 09:36 PM
Views 884
25-06-2020, 04:13 PM
Replies 18
Views 2,123
20-02-2020, 01:03 PM
Views 2,072
18-11-2019, 10:04 AM
