JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Engine oil level
Engine oil level
Engine oil level
Lee
07-06-2017, 09:41 AM
I've had a car inspection done and just had the report come back and it said that the oil level was too high. Just checked and it is about 5mm above the top mark.
Could this damage the engine?
What is the best way to take that little drop out?
Lee
07-06-2017, 09:41 AM #1
07-06-2017, 09:48 AM
I doubt that will cause any problem. If you're concerned about it then you could use a syringe or try and siphon some out with a piece of tubing if you like.
Edited 19-07-2009, 07:45 PM by steviewevie.
07-06-2017, 09:48 AM #2
Marcus_1UZ
07-06-2017, 03:04 PM
Right haveing to much oil in the engine is just as bad to not haveing any oil or haveing oil to low
just undo the oil plug in the sump, and take some out then just do it up once you are done....Smile
Edited 19-07-2009, 06:52 PM by Marcus_1UZ.
Marcus_1UZ
07-06-2017, 03:04 PM #3
Lee
07-06-2017, 03:06 PM
Marcus_1UZ just undo the oil plug in the sump, and take some out then just do it up once you are done....Smile
I was thinking that, but someone just PM'd me that Kwik Fit have a piece of kit they use to take some out from the top Huh
I'll give it a go, if it dry's up tomorrow, cheers Marcus.
Lee
07-06-2017, 03:06 PM #4
Marcus_1UZ
07-06-2017, 07:22 PM
Lee I was thinking that, but someone just PM'd me that Kwik Fit have a piece of kit they use to take some out from the top Huh
HHHMMM please tell me how you are going to get oil out the top of the engine when the oil sit,s in the sump, you say that its 5mm over the max mark, the best way of geting oil out and it will take you 5min,s to do so is from the sump!!! for it to be over by 5mm you have about 1 or 2 lt,s more than you should have!!
Marcus_1UZ
07-06-2017, 07:22 PM #5
Lee
07-06-2017, 07:40 PM
Marcus_1UZ HHHMMM please tell me how you are going to get oil out the top of the engine when the oil sit,s in the sump, you say that its 5mm over the max mark, the best way of geting oil out and it will take you 5min,s to do so is from the sump!!! for it to be over by 5mm you have about 1 or 2 lt,s more than you should have!!
I was wondering the same tbh.
1 or 2 ltrs :o
Lexus filled it on the last service so just assumed it was right.
Looks like i'm going to get mucky tomorrow night Smile
Lee
07-06-2017, 07:40 PM #6
1 or 2 ltrs :o
07-06-2017, 08:12 PM
remember though only check your oil when cold and on a level surface!!!!when its warmed up it will be higher up the dipstick.
07-06-2017, 08:12 PM #7
Marcus_1UZ
07-06-2017, 09:55 PM
ormi remember though only check your oil when cold and on a level surface!!!!when its warmed up it will be higher up the dipstick.
yea good point there:thumbup1:
Marcus_1UZ
07-06-2017, 09:55 PM #8
Marcus_1UZ
07-06-2017, 09:59 PM
Lee I was wondering the same tbh.
1 or 2 ltrs :o
no its not a mucky job mate, you will be ok, just get the sump nut 2 or 3 turn,s and the oil should start to come out ( what ever you do dont take the nut all the way out, or you will get mucky lol) then just do it back up when you got some oil out....
Marcus_1UZ
07-06-2017, 09:59 PM #9
1 or 2 ltrs :o
08-06-2017, 04:39 AM
Lee you should of popped over to see my brother, he has one of the suction kits that kwik fit use and they take it out of the dip stick hole by sliding a pipe down it and then they pump it out using a vacuum pump, Smile great bit of kit and saves getting dirty CLICK ME! And it gets nearly all the oil out of the sump :thumbup1:
Edited 20-07-2009, 08:27 AM by Bandit.
08-06-2017, 04:39 AM #10
Views 424
15-04-2023, 09:06 AM
Views 572
15-01-2023, 08:08 AM
Views 1,123
17-08-2022, 09:38 AM
Last Post by mattlaw
Views 665
23-04-2021, 03:50 AM
Last Post by S
Views 975
01-04-2021, 08:42 AM
Views 453
10-03-2021, 05:19 AM
Views 1,190
14-11-2020, 09:36 PM
Views 890
25-06-2020, 04:13 PM
Replies 18
Views 2,145
20-02-2020, 01:03 PM
Views 2,091
18-11-2019, 10:04 AM
