JapCarForum Club Sponsor MeisterR IS200 Europa Coilovers Offer!
MeisterR
01-01-2019, 08:35 PM
[SIZE="2"]
[SIZE="4"]Introductory Offer for MeisterR Europa Coilovers for Lexus IS200 / Altezza (GXE10 / SXE10)
RRP: £660 ( Introductory Price: £560 + P&P!!! )[/SIZE]
[Image: IS200.jpg]
The Specification of the Europa Coilovers:
*Aluminium Top Mount with Harden Rubber Bushing
*Extended Rear Aluminum Top Mount
*Monotube damper with 32 stage damping adjustment (Compression and Rebound Combined)
*Linear Rate SAE9254 Chrome Silicon Steel Springs
*Lengthen Heavy Duty Rubber Boot and Bump Stop
*Aluminium Spring Perch, Locking Collar, and Lower Bracket
*Dual Perch Coilovers Construction (Independent Ride Height and Spring Tension Adjustments)
IS200 / Altezza Spring Rate:
Front: 8.0 kg/mm (448lb/in)
Rear: 6.0 kg/mm (336lb/in)
How to order? Price?
As I would like to get some initial feedback from user, I am discounting the price £100 off the RRP.
All I ask in return is a few pictures of your IS200 / Altezza for the gallery and some feedback so we all know what you think of the MeisterR coilovers.
I will run this as an "Offer", so there will no need to wait for enough people to join as that is where most group buy falls apart.
Simply add your name to the list and drop me a PM, I will then give you a voucher code for the discount.
The IS200 Europa coilovers are in stock and all ready for next day delivery (Delivery is £15 for UK Mainland)
But since the stocks are limited it will work on a First Come First Serve basis.
If you have any concerns, please feel free to PM me or E-mail me at [email protected]
The List:
1.
2.
3.
4.
5.
I am happy to offer the discount to Outlaw members with other makes and model, please contact me if you have any interests and I'll work something out for you. :thumbup1:
[/size]
MeisterR
01-01-2019, 08:35 PM #1
[SIZE="2"]
[Image: IS200.jpg]
The List:
1.
2.
3.
4.
5.
[/size]
MeisterR
01-01-2019, 08:36 PM
[SIZE="2"]
Details of MeisterR Europa Coilovers for Lexus IS200 / Altezza (GXE10 / SXE10)
Aluminum Top Mount with Harden Rubber Bushing.
Anodised Red Aluminum Top Mount replace your old and tired steel top mount.
The harden rubber bushing are able to provide precise steering feedback while absorbing NVH (Noise, Vibiration, Harshness).
Making this a better option for fast road use.
[Image: TopMount.jpg]
MonoTube Dampers with Black Chromium Plated Body, Cold Coiling SAE9254 Chrome Silicon Steel Springs
MonoTube Dampers ensure high performance damping quality and ability to dissipate heat under hard usage.
The Black Chromium Plating have endure salt spray test and is by far the best plating available.
There are 32 stage damping adjustment (Compression and Rebound Combined).
Lengthen Rubber Boot ensure the damper piston will be protected from harsh environment.
The Cold Coiled Linear Rate Springs use high grade SAE9254 Steel to ensure strength and provide linear and predictable weight transfer characteristic.
[Image: Springs.jpg]
Anodised Aluminium Spring Perch and Locking Collar
Lightweight Aluminium Collars are use to lock your springs and brackets in place.
The "Polyamide" springs isolator are use to reduce noise and spring binding issue associated with rubber isolator.
[Image: Collars.jpg]
Aluminium Lower Bracket
Lightweight Aluminium Bracket are used to reduce unsprung weight even further.
[Image: Bracket.jpg]
[/size]
Edited 13-02-2011, 12:24 AM by MeisterR.
MeisterR
01-01-2019, 08:36 PM #2
[SIZE="2"]
[/size]
01-01-2019, 09:08 PM
Great offer. Wish I was in a position to snap these up!
01-01-2019, 09:08 PM #3
14-02-2019, 08:19 PM
Would these fit and work on an IS300 Sportcross?
14-02-2019, 08:19 PM #4
MeisterR
15-02-2019, 05:21 AM
Dark Samurai Would these fit and work on an IS300 Sportcross?
Yes, they will fit an IS300 Sportcross also. Smile
MeisterR
15-02-2019, 05:21 AM #5
15-02-2019, 05:33 AM
Great! Will talk to my father!
15-02-2019, 05:33 AM #6
16-02-2019, 06:34 AM
Also did you say they are height adjustable? What is the range? How low do they go?
16-02-2019, 06:34 AM #7
Phil01
16-02-2019, 07:42 AM
Oli they are fully adjustable by adjusted mg the body length rather.than just adjusting spring length, this is the best type of adjustment as you keep the spring compression rate the same.
You can go as low as you want with these colillies, just waiting for next months bonus to come through and I will be driving Meister R in sittingbourne to collect a set
Sent from my GT-I9000 using Tapatalk
Phil01
16-02-2019, 07:42 AM #8
MeisterR
16-02-2019, 08:35 AM
You won't have any issue with ride height adjustment on these.
The length of the damper is very long on the IS200/300, so there are loads of height adjustments.
Like Phil said, you change the ride height by adjusting the "length" of the damper, therefore springs tension, damper travel, and ride quality do not change from adjusting the ride height.
This give much more control over what you want the car to do, and it also mean you can go low while still retaining a comfortable and compliant ride quality. Smile
MeisterR
16-02-2019, 08:35 AM #9
ekme
16-02-2019, 09:12 AM
How many people have taken up the offer and what do they feel like?
ekme
16-02-2019, 09:12 AM #10
Views 1,396
06-11-2023, 07:41 PM
Last Post by MeisterR
Views 2,295
02-12-2022, 10:31 AM
Views 2,150
02-06-2020, 09:50 AM
Last Post by speedfreek
