JapCarForum Club Sponsor Auto Rae Chem Do you have
Do you have
Do you have
03-01-2019, 04:46 PM
Hi do you offer pads to fit a Meguiars g220 they don't have to be the real MaCoy
As long as they are good quality and give a good result?
Thanks
03-01-2019, 04:46 PM #1
Thanks
03-01-2019, 04:59 PM
Good question! im interested in a couple
03-01-2019, 04:59 PM #2
AutoRaeChem
04-01-2019, 08:09 AM
i am sorry i don't really do this type of thing i will have a look and see what i can source
AutoRaeChem
04-01-2019, 08:09 AM #3
04-01-2019, 08:20 AM
will be keeping an eye on this as im after some more along with cutting agents for the paint..
04-01-2019, 08:20 AM #4
04-01-2019, 08:40 AM
Lexusboy Hi do you offer pads to fit a Meguiars g220 they don't have to be the real MaCoy
Thanks
Also for the UDM would be good Smile
04-01-2019, 08:40 AM #5
Thanks
dodgydave
04-01-2019, 09:54 AM
SHAHZ Also for the UDM would be good Smile
You have a polisher :laugh:
dodgydave
04-01-2019, 09:54 AM #6
04-01-2019, 01:01 PM
This is some information that Christian gave me ............
You wont go wrong with the Menzerna range. As far as pads, the sonus cutting pad is quite good and you may need this when using a G220. Moving into polishing and finishing pads i like Meguiars and 3M. Due to the design of the 3M, they feel better for being more accurate with getting into tighter areas, but the 3m are slightly softer and compress more easily which is nice on a rotary but on a G220 you might be better with meguiars. You will probably want to consider some spot polishing pads for smaller areas such as bumpers and skirts. For these i do like the sonus ones. You will also find that spot pads on a G220 will offer more cut than a larger pad because you can concentrate on particular areas more often. On a rotary it is the opposite, the larger pads offer more cut as they spread more heat across an area at once. But remember if you do buy any spot pads, you will also need to buy a smaller backing plate as well, and therefore dont forget to draw a black line on that one to so you can check how often it is rotating. Hopefully i have explained this ok, just shout if your now more confused .
04-01-2019, 01:01 PM #7
AutoRaeChem
18-01-2019, 08:05 AM
YES
These have been recommended to be by a customer of mine who sells loads and has no complaints about the quality.
So here goes.... will be in stock next week
FLEXIPADS
180mm (7") Maroon "ULTIMATE" Velcro S/Buff Cutting Pad
[Image: MAROONPAD.jpg]
Features
Ideal for removing Heavy - Medium defects, swirl marks and scratches
180mm (7") Yellow "ULTIMATE" Velcro S/Buff Polishing Pad
[Image: YELLOWPAD.jpg]
Features
Ideal for removing Light - Medium defects, swirl marks and scratches
180mm (7") Black "ULTIMATE" Velcro S/Buff Finishing Pad
[Image: BLACKPAD.jpg]
Features
Ideal for applying Glazes, Waxes and Sealants for the refinishing process
All pads are:
180mm (7") in size with new ultra smooth buffing technology
Reduces chatter resulting in easy buffing
Recessed pad backing for easy backing plate centering
Velcro for fast fixing
Durable, High-Tech laminate for long pad life
Machine washable
Ideal with our 150mm Rotary Ultra Soft Backing Plate Item 10400
Width: 180mm
Depth: 32mm
Max RPM: 2,500
1 Pads @ £8.60 + postage @ £1.95
3 Pads @ £22.50 = £7.50 ea + postage @ £2.49
As usual if you would like to order then please send a payment to paypal using GIFT OPTION to [email protected]
along with your name, address and what you require
AutoRaeChem
18-01-2019, 08:05 AM #8
YES
FLEXIPADS
Features
Features
Features
All pads are:
Machine washable
Width: 180mm
Depth: 32mm
Max RPM: 2,500
