JapCarForum Trade Area Selling MeisterR Coilovers Group Buy Offer!
Pages (3): 1 2 3 Next
MeisterR
10-01-2019, 05:09 PM
[SIZE="2"]
[SIZE="4"]Introductory Offer for MeisterR Europa Coilovers for Lexus IS200 / Altezza (GXE10 / SXE10)
RRP: £660 ( Introductory Offer: £100 OFF!!! )[/SIZE]
[Image: IS200.jpg]
The Specification of the Europa Coilovers:
*Aluminium Top Mount with Harden Rubber Bushing
*Extended Rear Aluminum Top Mount
*Monotube damper with 32 stage damping adjustment (Compression and Rebound Combined)
*Linear Rate SAE9254 Chrome Silicon Steel Springs
*Lengthen Heavy Duty Rubber Boot and Bump Stop
*Aluminium Spring Perch, Locking Collar, and Lower Bracket
*Dual Perch Coilovers Construction (Independent Ride Height and Spring Tension Adjustments)
IS200 / Altezza Spring Rate:
Front: 8.0 kg/mm (448lb/in)
Rear: 6.0 kg/mm (336lb/in)
How to order? Price?
As many Outlaws are on IS200, that is why this post is center on the IS200 Europa Coilovers.
However, i am happy to offer the same deal for other makes and models, so just contact me if you have any questions. :thumbup1:
As I would like to get some initial feedback from user, I am discounting the price £100 off the RRP.
All I ask in return is a few pictures of your IS200 / Altezza for the gallery and some feedback so we all know what you think of the MeisterR coilovers.
I will run this as an "Offer", so there will no need to wait for enough people to join as that is where most group buy falls apart.
Simply add your name to the list and drop me a PM, I will then give you a voucher code for the discount.
The IS200 Europa coilovers are in stock and all ready for next day delivery (Delivery is £15 for UK Mainland)
But since the stocks are limited it will work on a First Come First Serve basis.
If you have any concerns, please feel free to PM me or E-mail me at [email protected]
The List:
1.
2.
3.
4.
5.
[/size]
Edited 21-02-2011, 09:00 PM by MeisterR.
MeisterR
10-01-2019, 05:09 PM #1
[SIZE="2"]
[Image: IS200.jpg]
The List:
1.
2.
3.
4.
5.
[/size]
MeisterR
[SIZE="2"]
[SIZE="4"]Details of MeisterR Europa Coilovers
Lexus IS200 / Altezza (GXE10 / SXE10) [/SIZE]
Aluminum Top Mount with Harden Rubber Bushing.
Anodised Red Aluminum Top Mount replace your old and tired steel top mount.
The harden rubber bushing are able to provide precise steering feedback while absorbing NVH (Noise, Vibiration, Harshness).
Making this a better option for fast road use.
[Image: TopMount.jpg]
MonoTube Dampers with Black Chromium Plated Body, Cold Coiling SAE9254 Chrome Silicon Steel Springs
MonoTube Dampers ensure high performance damping quality and ability to dissipate heat under hard usage.
The Black Chromium Plating have endure salt spray test and is by far the best plating available.
There are 32 stage damping adjustment (Compression and Rebound Combined).
Lengthen Rubber Boot ensure the damper piston will be protected from harsh environment.
The Cold Coiled Linear Rate Springs use high grade SAE9254 Steel to ensure strength and provide linear and predictable weight transfer characteristic.
[Image: Springs.jpg]
Anodised Aluminium Spring Perch and Locking Collar
Lightweight Aluminium Collars are use to lock your springs and brackets in place.
The "Polyamide" springs isolator are use to reduce noise and spring binding issue associated with rubber isolator.
[Image: Collars.jpg]
Aluminium Lower Bracket
Lightweight Aluminium Bracket are used to reduce unsprung weight even further.
[Image: Bracket.jpg]
[/size]
Edited 28-02-2011, 10:48 AM by MeisterR.
MeisterR
10-01-2019, 05:09 PM #2
[SIZE="2"]
[/size]
10-01-2019, 05:23 PM
come on guys any takers on these they sound great...
10-01-2019, 05:23 PM #3
James S
15-01-2019, 12:25 PM
I'm interested, going to try get a new credit card ordered! LOL!
James S
15-01-2019, 12:25 PM #4
MeisterR
17-01-2019, 07:15 AM
Big Grin Well, let me know when you are ready as the coilovers are in stock and ready for delivery.
And just to remind everyone that the offer is for all MeisterR coilovers across the board.
So if anyone are interested in coilovers for other model, just let me know and I'll sort you out. Smile
MeisterR
17-01-2019, 07:15 AM #5
17-01-2019, 04:47 PM
If my car wasn't for sale I would have snapped your hands off for a set. They are ideal for raising the ride height for everyday driving and slamming for shows.
17-01-2019, 04:47 PM #6
daz
26-01-2019, 12:56 PM
Very interested but on a budget :-(
These look better then the D2 coilovers but been offered these at under £500 delivered, choices choices lol
daz
26-01-2019, 12:56 PM #7
MeisterR
26-01-2019, 01:11 PM
daz Very interested but on a budget :-(
I know I am not the cheapest, but I guess it is something I never aim to be.
What I aim is to provide the best value for money, and product quality is one of them.
We spend time working on the damper valving and the springs rate to make sure the suspension will provide both comfort and performance.
Also, if anything goes wrong you know who to talk to, and I always make sure I'll sort out any problem there are.
How often have you heard people with leaking D2 dampers but no one to service them.
I myself get regular inquiry on if I can help fix D2 dampers... and unfortunately, I am not able to help.
This is one of those case it is worth spending a little more to begin with, because chances are that they will cost you less in the long run. Smile
MeisterR
26-01-2019, 01:11 PM #8
26-01-2019, 10:04 PM
I'd like a set, but funds are committed in a couple of other places at the moment. Should be able to afford them in perhaps a month or two - they do look pretty sweet...
26-01-2019, 10:04 PM #9
MeisterR
27-01-2019, 06:48 AM
DaveEdin I'd like a set, but funds are committed in a couple of other places at the moment. Should be able to afford them in perhaps a month or two - they do look pretty sweet...
Yes, they look even better in person.
But most importantly, they are well build and build to perform... I made sure of that. Smile
Again, this deal isn't for IS200 only.
The discount applies to all MeisterR Coilovers model so anyone with any car from OLJ can get the same discount. Smile
MeisterR
27-01-2019, 06:48 AM #10
Views 1,064
24-12-2024, 07:11 AM
Views 306
28-05-2023, 10:48 AM
Last Post by P.Lindblom
Replies 33
Views 2,444
14-03-2023, 05:03 PM
Last Post by cjoseph
Views 902
31-01-2022, 10:48 AM
Views 263
31-12-2021, 09:32 PM
Last Post by MeisterR
Replies 426
Views 37,261
13-12-2021, 04:37 PM
Last Post by jasons
Replies 52
Views 3,732
26-02-2021, 06:26 AM
Last Post by NappyBoy
Views 554
31-01-2021, 09:58 PM
Last Post by Colin G
