JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications TTE supercharger reconditioning
fido99
16-03-2019, 05:22 AM
Hello,
does anybody know how to disassemble the rotors of the charger and the gears (cog wheels)? I need to disassemble the gears from the rotors in order to check/change the bearings if necessary. As I do not want to damage anything, I am seeking for any experience from anyone who already disassembled the charger. Here is the link to a post, where the charger was opened, however abactus did not disassemble this part. Thank you for any advice !!! Jan
fido99
16-03-2019, 05:22 AM #1
Hello,
16-03-2019, 06:12 AM
There is a walkthrough on how to do it here in the workshop section I think mate
16-03-2019, 06:12 AM #2
fido99
16-03-2019, 09:04 AM
I forgot to quote the link that I mentioned...you probably mean this one: http://www.outlawjapclub.co.uk/forum/sho...php?t=3213
However, gears are not being removed here....any ideas?
fido99
16-03-2019, 09:04 AM #3
rob
16-03-2019, 10:21 AM
DO NOT try to take it apart..... the rotors and the shaft are seperate and and are aligned similarto engine timing. If you get it slightly wrong then the charger is scrap.
The bearings are standard items, however the seals are a special size and can not be bought over the counter, they were specially made for eaton.
rob
16-03-2019, 10:21 AM #4
fido99
16-03-2019, 10:29 AM
I already have all the parts including bearings and seals, but I found that rotors are timed and that it requires special service to disassemble it and put it back properly aligned and timed. I will try to change all the other bearings and snout seal and I hope it will be fine. Thanks for your ideas !!!
fido99
16-03-2019, 10:29 AM #5
rob
20-03-2019, 12:47 PM
fido99 I already have all the parts including bearings and seals, but I found that rotors are timed and that it requires special service to disassemble it and put it back properly aligned and timed. I will try to change all the other bearings and snout seal and I hope it will be fine. Thanks for your ideas !!!
which bearings and seals do you have, I assume you have the rear rotor support bearings and the small seal for the drive shaft?
rob
20-03-2019, 12:47 PM #6
fido99
21-03-2019, 04:26 AM
I got complete kit including those that I am probably not going to need...I bought everything before I realized that the part between rotors and gears is repairable probably by Eaton only (at least in US). I will try to change the ones that you mentioned and I will see if there will be some oil leak from gears to rotors and if the noise will be acceptable. I am refurbishing it as I bought it used and I want to make sure that it will be in perfect condition before I put it in my car so maybe this will be sufficient. Thnak you for your ideas.
fido99
21-03-2019, 04:26 AM #7
rob
21-03-2019, 01:52 PM
ok, my advise is double check the part numbers for the rear rotor bearings as there are different sizes and the shaft oil seal( snout seal) also has different sizes if it is a MB unit or a standard eaton unit. Standard eaton unti has a seal about 25mm across.
rob
21-03-2019, 01:52 PM #8
Views 3,082
28-05-2024, 10:57 PM
Last Post by Mikedaddy
Views 1,384
22-05-2024, 06:15 AM
Last Post by ashj25839
Views 785
05-04-2024, 07:48 AM
Replies 24
Views 2,587
12-01-2024, 05:42 PM
Views 510
03-01-2024, 07:08 PM
Views 336
28-12-2023, 04:46 AM
Views 716
02-12-2023, 07:46 PM
Views 747
04-11-2023, 11:43 AM
Views 243
30-07-2023, 07:38 PM
