JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Bodywork warranty
Bodywork warranty
Bodywork warranty
10-04-2019, 02:13 PM
Is the warranty 12 years on bodywork? Just noticed I have some corrosion on my left rear inner wheelarch - interestingly it's the wing that was replaced after an accident in 05 (other side looks fine).
Going to show it to my dealer, but if they don't agree to do it under warranty what options do I have? Is it something that will need to go into the bodyshop?
10-04-2019, 02:13 PM #1
Tango
10-04-2019, 02:39 PM
parthiban Is the warranty 12 years on bodywork? Just noticed I have some corrosion on my left rear inner wheelarch - interestingly it's the wing that was replaced after an accident in 05 (other side looks fine).
You may be lucky with Lexus, but the extended corrosion warranty is usually only applicable if the panel is perforated i.e. surface corrosion isn't covered.
Tango
10-04-2019, 02:39 PM #2
Marsdendean Do you not have a warranty with the bodyshop? I was given a lifetime limited warranty. My bonnet was going rusty and turned out it needed a new one, so they had to do it!
its 12 years but won't do it if its not been to a lexus approved one, since the paint wont be lexus approved - thats what i was told
Yep it was a Lexus bodyshop so no issues there but as it's a wheel arch not sure if they'll say it's due to salt/stonechips/etc.
Will get it checked out next week if I can.
10-04-2019, 02:39 PM #3
10-04-2019, 02:40 PM
Tango You may be lucky with Lexus, but the extended corrosion warranty is usually only applicable if the panel is perforated i.e. surface corrosion isn't covered.
Ahh in that case perhaps I won't get anything as it is just on the surface. Isn't that a bit silly though, as surely it's cheaper and easier to sort surface rust - and surface rust will eventually go all the way through potentially?
10-04-2019, 02:40 PM #4
Tango
10-04-2019, 03:25 PM
parthiban Ahh in that case perhaps I won't get anything as it is just on the surface. Isn't that a bit silly though, as surely it's cheaper and easier to sort surface rust - and surface rust will eventually go all the way through potentially?
It would be worth checking with a dealership, but I think it's been the subject of a few posts on LOC and almost all were turned down. You'd probably have a case if you could prove it was due to shoddy preparation e.g. poor primer coat causing corrosion to bubble up under undamaged topcoats.
A mate with an old Audi estate had a perforated tailgate due to rust after a lot more than 12 years and Audi replaced the entire tailgate. :thumbup1:
Tango
10-04-2019, 03:25 PM #5
10-04-2019, 04:37 PM
Cool, I'll take it in next week and fingers crossed they'll sort it out Smile
10-04-2019, 04:37 PM #6
09-05-2019, 08:17 AM
Finally got around to taking the car in this morning and unfortunately I'm not sure if this will be covered - they're not sure so going to check with Lexus but they said that only the original bodywork is covered for 12 years, replacement panels are just whatever the bodyshop gives you (which in this case is 3 years).
I was always under the impression that if the work was Lexus approved the original warranty still stands - does anyone know whether that's true or not?
09-05-2019, 08:17 AM #7
Views 650
25-04-2020, 06:05 PM
Last Post by jasons
