JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning over the hump?
over the hump?
over the hump?
24-04-2019, 08:56 AM
I need to get a short and quite fat bundle of cables from under the drivers seat to under the passenger seat. Obviously the driveshaft hump in the middle makes things quite difficult.
Anyone got any recommendations of good ways to route it?
24-04-2019, 08:56 AM #1
24-04-2019, 09:00 AM
Is this the cabling for the pc build?
Can you get it under the carpet feed it under the back seats and round the other side?
24-04-2019, 09:00 AM #2
24-04-2019, 09:22 AM
Yeah its kinda for the PC. Basically I've got a Zeitronix zt2 that needs to be hooked up to the Car PC which is underneath the passenger seat. However as the bung for the o2 sensor is over on the drivers side it makes the most sense (i think) to come up under the drivers seat then run the o2 sensor cable over to the passenger side.
Back seats might be an option, but I think unless I can cut some corners, the cable will be too short Confused
24-04-2019, 09:22 AM #3
24-04-2019, 09:32 AM
the carpet is very tight over the hump and i think it would look untidy to try and get it over the hump
you might be better extending the cables and going up and over the dash section of the hump....
could you not mount the main unit behind the dash ?
Rabs
24-04-2019, 09:32 AM #4
Rabs
24-04-2019, 11:36 AM
Come to think about it, under the dash could work quite well. Its where i had my PLX wideband, but I didn't want to put the zeitronix under there as it seemed to have some kind of custom data cable that would be quite hard to extend neatly. However, the more I look at the wire the more it looks like an RJ11 telephone cable. So I might see if an extension for that will work.
24-04-2019, 11:36 AM #5
