JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Lexus Misfiring, please Help!!!!
Pages (4): 1 2 3 4 Next
jayson2323
24-04-2019, 08:57 AM
I was driving my lexus is200 today and all of a sudden it started misfiring, no engine light came on until I got near my house then the engine light started flashing and then stopped, the car is still going but you can actually hear the misfire, I do not have access to a diagnostic tool right now, does anyone have any ideas what it may be or what I can do to check?
jayson2323
24-04-2019, 08:57 AM #1
24-04-2019, 08:59 AM
Could be a spark plug or coilpack. Would need an OBD2 reader to find the engine code to say which cylinder is misfiring mate.
24-04-2019, 08:59 AM #2
jayson2323
24-04-2019, 09:03 AM
thanks mate, any recommendations on an obd2 reader from fleabay?
jayson2323
24-04-2019, 09:03 AM #3
24-04-2019, 09:04 AM
To check what DarkS has recommended and he could be spot on why not remove a Spark plug at a time, you can then find out what one has broken down.
24-04-2019, 09:04 AM #4
jayson2323
24-04-2019, 09:06 AM
this might be a dumb question but would I remove the spark plug 1 at a time while the engine is running or no?, also would the car not misfire if I removed 1 spark plug and coilpack?
jayson2323
24-04-2019, 09:06 AM #5
24-04-2019, 09:19 AM
Yes remove one at a time with engine off if the engine does not change as it is currently running then it that one that is faulty.
Best to leave it to a dealer or have a ob2 reader plug in to find the code.
What age is your car?
24-04-2019, 09:19 AM #6
24-04-2019, 09:22 AM
Yes mate OBD2 from eBay are alright. Where abouts are you located? And Remove one coilpack at a time by just unplugging the connector on top of the rocker cover. If you unplug a working one then the engine will cut out. If you remove the faulty one the engine should keep going...
24-04-2019, 09:22 AM #7
jayson2323
24-04-2019, 09:38 AM
thanks guys, I will give that a go, just want peace of mind really, if it is a coilpack it will put me at ease as they are not that expensive to replace, Dark Samurai I live in Northampton, why do you live near me?, I will try this and see what happens, hopefully it is something simple, there are so many obd2 readers on ebay, any particular ones you recommend?
jayson2323
24-04-2019, 09:38 AM #8
24-04-2019, 09:43 AM
OBD2 compatible is for car built after 2001 on PETROL and 2004 onwards for DIESEL
24-04-2019, 09:43 AM #9
24-04-2019, 10:05 AM
No Ian it's from 1999 because the earlier IS200 had OBD2 ports.
No mate I live in dartford was just wondering where you were located to see if anyone would help you out if they lived nearby?
I dont recommend any mate but will have a look in a minute when I'm on my computer.
24-04-2019, 10:05 AM #10
Views 1,667
06-11-2023, 07:38 AM
Views 631
18-10-2022, 07:53 AM
Views 565
04-09-2022, 01:09 AM
Last Post by Ratchet
Views 958
03-09-2022, 04:53 PM
Replies 35
Views 9,424
04-08-2022, 10:23 AM
Last Post by cjoseph
Replies 128
Views 10,548
20-08-2021, 02:58 PM
Last Post by Fry-Up
Views 2,153
17-06-2020, 05:41 PM
Views 629
25-04-2020, 06:05 PM
Last Post by jasons
Views 578
19-03-2020, 03:39 PM
Views 761
26-02-2020, 02:38 PM
Last Post by rosey1955
