JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Brake fluid change
Brake fluid change
Brake fluid change
aaronabbott
04-05-2019, 12:03 PM
How much will I need for a complete change,
And what's the best way to do it?
aaronabbott
04-05-2019, 12:03 PM #1
04-05-2019, 04:12 PM
2 lrt max...
get a mate too sit in the car and give 15 pumps per caliper checking the level after each caliper...and remember on the last pump hold the pedal down then tighten the niple
he will not thank you........his leg will be killing him...lol
04-05-2019, 04:12 PM #2
2 lrt max...
aaronabbott
04-05-2019, 09:34 PM
i was told to start at the furthest corner away from the resovoir is this true
aaronabbott
04-05-2019, 09:34 PM #3
05-05-2019, 06:26 PM
nope doesnt make any odds matey start at what ever one you want..
05-05-2019, 06:26 PM #4
Phil01
06-05-2019, 04:23 AM
You can start the engine for the servo action as that will make pumping so much easier.
But as Ormi pointed out,, keep an eye on the fluid level after bleeding each corner.
Phil01
06-05-2019, 04:23 AM #5
LEXOB
11-04-2020, 06:51 PM
Rather than starting a new thread thought id post here.
Im changing discs and pads all round this weekend so thought i may as well get the brake fluid changed bleed the brakes etc. Also replacing a poxy sticking front caliper with a recon one.
I read above that Ormi says 2 litres max to change the fluid, i was told up to 5 litres! I've also used the search function and found most of you recommend DOT 5.1. I'm not trying to cut corners, but the discs, pads, caliper plus handbrake shoes cost a bit and was wondering if DOT4 would suffice?
I'm putting on standard genuine parts all round, I have no power mods so would i really benefit from DOT 5.1 as opposed to DOT4? And you definitely think if i ordered 3 litres that would be enough?
What about Goodridge hoses? Been looking at these too. Anything i should check out/replace or use while i'm at it?
LEXOB
11-04-2020, 06:51 PM #6
11-04-2020, 07:27 PM
5 lrts your kidding..I do changes day in day out and day in...can you imagin the customers reaction at the price using 5 lrts..trust me 2 lrts is more than enough!!
11-04-2020, 07:27 PM #7
LEXOB
11-04-2020, 07:51 PM
Haha you should've seen my reaction when I heard 5ltrs! Then my reaction when I priced up 5ltrs of Motul DOT 5.1!! 2ltrs it is then.
Still torn on which grade/type to get?
LEXOB
11-04-2020, 07:51 PM #8
12-04-2020, 06:38 PM
Get the grade the manufacturer recommends.
12-04-2020, 06:38 PM #9
LEXOB
12-04-2020, 06:46 PM
I've already ordered Motul DOT 5.1 as recommended by most members on here. Going to do it all next week so hopefully I'll feel a big difference. Only thing I'm not doing is new hoses.
LEXOB
12-04-2020, 06:46 PM #10
Views 492
16-06-2023, 09:40 AM
Views 792
12-12-2021, 04:40 PM
Last Post by phaebo
Views 1,021
16-10-2021, 01:21 PM
Last Post by Mr-cth
Views 1,115
23-03-2021, 10:08 PM
Views 1,405
10-11-2020, 07:29 AM
Views 1,050
29-07-2020, 01:49 PM
Views 1,367
11-01-2020, 05:10 PM
Views 1,471
01-07-2019, 07:30 AM
Last Post by E55EX_RACER
Views 434
28-12-2018, 11:13 PM
Last Post by LEX11S
Views 1,281
24-12-2018, 01:34 PM
Last Post by aaronabbott
