JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications Injector plugs - anyone spotted these in their travels:
04-05-2019, 06:12 PM
I'm looking for some Nippon Denso male injector connectors like this:
[Image: NipponDensoMSM.png]
There's a few places in the USA that sell them but I'm trying to avoid the wait for them to arrive.
Taa
04-05-2019, 06:12 PM #1
Taa
04-05-2019, 06:37 PM
are they the oem 1gfe ones as i have a set of 6
04-05-2019, 06:37 PM #2
04-05-2019, 06:44 PM
What happened to your 6, Jim?
04-05-2019, 06:44 PM #3
04-05-2019, 07:40 PM
Are they the same ones we had to find for Stevie? I've got a big pdf of all Toyota wiring connectors I linked to somewhere on here, in the Toyota manuals section I think?
Edit: Here you go: http://theshado.ws/images/Wire%20Harness%20Repair.pdf
I am pretty sure this is the same connector I sourced for Stevie, they are used for injectors in MKIII and MKIV Supras?
04-05-2019, 07:40 PM #4
04-05-2019, 08:37 PM
dont know if this will help
http://www.lextreme.com/Injector%20data.htm
04-05-2019, 08:37 PM #5
05-05-2019, 02:49 AM
I think these may be a bit harder to source, as it's the style of plug you'll find on the actual injector rather than the harness that plugs into the injector.
What I'm trying to do is make a cable that will allow me to plug EV1 injectors into the denso factory harness without cutting any wires.
It's a long shot I know.
05-05-2019, 02:49 AM #6
05-05-2019, 04:00 AM
just remove the pins from the plugs and swap out the plastic case if they are they same size. thats what i did.
05-05-2019, 04:00 AM #7
05-05-2019, 05:23 AM
jay_russell just remove the pins from the plugs and swap out the plastic case if they are they same size. thats what i did.
Hmm thats an interesting idea. I'll have a look and see how they compare. I have a feeling that the EV1 connectors I've got are sealed though, so it might not be possible.
05-05-2019, 05:23 AM #8
Views 673
09-09-2023, 06:48 PM
Views 287
03-05-2021, 11:12 AM
Last Post by buzzard2011
Views 1,355
03-10-2020, 06:40 PM
Last Post by jimxms
Views 608
15-09-2020, 10:34 AM
Last Post by liquidlazer
Views 1,027
29-02-2020, 01:52 PM
Last Post by LEX11S
Views 883
09-01-2019, 07:10 PM
Views 1,748
07-10-2018, 12:37 PM
Last Post by LEX11S
