JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza bit of help needed
bit of help needed
bit of help needed
FuntimePhil
23-05-2019, 04:07 PM
Ok, i was having a mess in the car the weekend, looking at cable routes for a handsfree mic. After looking around i decided i wanted to mount it by the drivers sun visor, so i pulled on the drvers side pillar a little to see if i could had cable behind it, and it popped off! Firstly i thought great, perfect cable route, but i cant get it back on, it doesnt clip in and now doesnt sit flush with the rest of the roof. ive pushed and banged n wiggled but it just wont clip in. Have i wrecked it?
FuntimePhil
23-05-2019, 04:07 PM #1
23-05-2019, 05:59 PM
Have you tucked it in at the bottom properly?
also have the clips come off with the pillar? they may need putting back in before the pillar
23-05-2019, 05:59 PM #2
FuntimePhil
23-05-2019, 06:07 PM
see i dont know what you mean about clips, there dont appear to be any? could they of fell off inside the metal frame?
FuntimePhil
23-05-2019, 06:07 PM #3
FuntimePhil
24-05-2019, 06:43 AM
if there are clips that i have lost, does anyone know the part numbers for them?
FuntimePhil
24-05-2019, 06:43 AM #4
24-05-2019, 06:50 AM
I think the clips Stav are refering too are likely to be still in the piller and not on the cover.
You have to remove them from the Piller and re fit them back onto the cover.
To remove your need to pinch them with Piller and pull them out.
24-05-2019, 06:50 AM #5
FuntimePhil
24-05-2019, 07:03 AM
is it possible they have fell into the frame of the car, as there are no clips on the trim, and when you look at the metal pillar there are just 2 empty metal holes (where i assume there should be clips)
FuntimePhil
24-05-2019, 07:03 AM #6
24-05-2019, 07:13 AM
Yes they could of fallen into the piller...
I see if I can find what I think is needed, I dont have the same car so can not confirm...
24-05-2019, 07:13 AM #7
FuntimePhil
24-05-2019, 07:15 AM
******, im i right in thinking if they have gone into the pillar they are lost for ever?
FuntimePhil
24-05-2019, 07:15 AM #8
24-05-2019, 07:32 AM
This is not the clip but it looks like this sort of clip...
http://www.clipsandfasteners.com/Toyota_...a16306.htm
24-05-2019, 07:32 AM #9
24-05-2019, 07:34 AM
You may be able to locate the clip, the magnet ariels come in handy for tight places
24-05-2019, 07:34 AM #10
Views 1,487
02-04-2021, 05:54 PM
Last Post by is300_dino
Views 627
02-12-2020, 08:47 AM
Views 514
30-11-2020, 11:10 AM
Views 1,130
02-05-2020, 11:49 AM
Views 850
21-04-2020, 09:12 AM
Last Post by Tomcat
Views 1,436
09-01-2020, 05:55 PM
Last Post by S
Views 2,016
14-12-2019, 02:47 PM
