JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza rear brakes.
rear brakes.
rear brakes.
30-05-2019, 05:24 AM
was wondering if anybody have put there front brakes on the rear, i'm going to replace my front ones soon and was thinking about the rears, if i could use the front oem units and mount them on the rear?
30-05-2019, 05:24 AM #1
30-05-2019, 01:07 PM
i suppose it could be done the most difficult part would be fabricating brackets and fixing points for them to attach to, but should be possible
30-05-2019, 01:07 PM #2
30-05-2019, 01:18 PM
You'd need a huuuuuge master cylinder as well!!
30-05-2019, 01:18 PM #3
30-05-2019, 01:27 PM
toxo You'd need a huuuuuge master cylinder as well!!
oh yeah forgot about the cylinder :blushing:
30-05-2019, 01:27 PM #4
30-05-2019, 02:19 PM
are is 300 rear brakes bigger than 200 or are they the same?
30-05-2019, 02:19 PM #5
30-05-2019, 02:44 PM
they are the same 1 pot type mate Sad
what do supras use on the rears i cant remember, so will have a search now for some
30-05-2019, 02:44 PM #6
30-05-2019, 03:57 PM
the fronts are 2 pot and the rears are the same....2 pot
the rears have 1 pot on each side of the disk the front has 2 pots on one side of the disk
Edited 11-07-2011, 07:42 PM by ormi.
30-05-2019, 03:57 PM #7
30-05-2019, 04:20 PM
so i might be able to get the fronts on the rears, i only run 18" or 20" so size is not a problem just if the master cylinder can handle it or better to find a bigger one?
30-05-2019, 04:20 PM #8
30-05-2019, 04:49 PM
the master cylinder should be able to cope mate..but you will need to run wider rear disks mate..
30-05-2019, 04:49 PM #9
30-05-2019, 04:54 PM
i still have my old fronts i changed out when i put drilled/slotted on
30-05-2019, 04:54 PM #10
Views 481
01-07-2022, 12:44 PM
Views 838
25-06-2022, 03:48 PM
Views 502
27-11-2021, 06:01 PM
Views 413
07-10-2021, 07:35 AM
Last Post by Stoney
Views 1,144
17-08-2021, 06:56 AM
Views 1,536
07-01-2021, 04:43 PM
Views 671
28-07-2020, 03:27 PM
Views 1,084
08-07-2020, 06:51 AM
Last Post by gc8_g_r
Views 753
17-06-2020, 09:03 AM
Last Post by Kevpr
