JapCarForum General Discussions The JCF Lounge building speakers parts list
Mikey
07-09-2019, 11:07 AM
I want to make some of these speakers
[Image: Proel_EX12P_49ede2c7f06ff.jpg]
could anybody tell me what is needed apart from MDF & carpet ie.. the internal electrical bits i was hoping to get a 10'' loud speaker and trumpet or 2
i have an 2 amps one with connection 1 and have a seperate amp with the connection 2 in this picture
[Image: P_Series_Amplifier_Rear%20djkit.jpg]
parts list needed asap
mike
Mikey
07-09-2019, 11:07 AM #1
mike
Fozzy
07-09-2019, 11:32 AM
PM Rabster, he is the AV expert around here
If your taking about the connectors top right in the pic they are speakons. Internally i dont believe there is a great deal, as all the control is done by the amplifier
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
07-09-2019, 11:32 AM #2
Mikey
07-09-2019, 12:52 PM
Cheers mate will wait for Rabster,
The speaker output / connector on one of the amps has the connector type 2 and the other amp has connector type 1.
just been having a look at these speakers thinking just go buy 2 of these
http://www.maplin.co.uk/300w-10-inch-loudspeaker-220544
[Image: n92fn.jpg]
Mikey
07-09-2019, 12:52 PM #3
[Image: n92fn.jpg]
Fozzy
07-09-2019, 01:10 PM
Ahh the old prosounds, Rabster had a couple of those years ago. Not the greatest sound out of them, if i recall they were a bit hazy in the midrange.
If your just thinking of buying stuff outright, let Rabster know how much you want to spend, im sure he will be able to suggest the best kit for your budget
Fozzy
07-09-2019, 01:10 PM #4
07-09-2019, 02:21 PM
I bet Rabster has kit lying about he could sell............
07-09-2019, 02:21 PM #5
Mikey
07-09-2019, 02:36 PM
Hurricane Ahh the old prosounds, Rabster had a couple of those years ago. Not the greatest sound out of them, if i recall they were a bit hazy in the midrange.
My budget is spend as little as i can but need them for this weekend just looking at some that are ending soon on ebay that are not to far away so can pick them up.
Mikey
07-09-2019, 02:36 PM #6
07-09-2019, 03:27 PM
If you are building, you will need to ensure that all drivers are of the right power and range for the application, that the cabinet is of the correct volume and partitioned/baffled appropriately. You will also need terminals for the rear, a crossover to direct the right signals to the right drivers and the correct gauge cable to solder it all together with. Also the speaker will probably sound best if ported, the number, size and position of the port(s) will depend upon many things.
I would recommend just buying used speakers if you are not experienced in building them, as you don't need to spend a lot to get decent kit these days, and it's a lot less hassle.
07-09-2019, 03:27 PM #7
Mikey
07-09-2019, 03:51 PM
Just won these sound lab Speakers will try and get them picked up asap might even go tonight if the seller is in.
Mikey
07-09-2019, 03:51 PM #8
Views 497
05-04-2021, 02:27 AM
Views 349
14-01-2021, 07:11 AM
Last Post by wullie_trd
Views 4,905
26-11-2019, 11:30 AM
Last Post by davidjamesbattersby
Views 2,134
08-05-2019, 02:52 PM
Last Post by John G
Replies 22
Views 3,013
01-05-2019, 04:08 PM
Last Post by nathjh
Views 2,150
01-03-2019, 07:00 AM
Views 1,224
22-02-2019, 05:32 PM
Last Post by is300_dino
Views 5,897
26-07-2018, 12:58 PM
Last Post by cameron
Views 1,487
14-06-2018, 09:50 AM
