JapCarForum Club Sponsor Likwidart Fitting Likwid Art Logos
08-10-2019, 05:24 PM
Glad you all like them.
Ok so fitting, I'm doing this from my phone so sorry for the spelling lol.
First clean the area you will be applying the graphic to. Do not use any oil based products. I use lighter fluid.
Then take you logo on the backing paper, and put a tab of masking tape at the top of the logo. This will be to hold it in place while you get it in place. Like this.
[Image: IMAG0043.jpg]
Then when you are happy with it, put a line of masking tape down the left-hand side. Make sure you put it right up to the backing paper like this
[Image: IMAG0044.jpg]
Then do the same at the bottom edge up to the backing paper like this
[Image: IMAG0045.jpg]
Now you have done this you will now have I line to show you where the logo goes back after you have taken off the backing paper. So now take off the logo and you should have this
[Image: IMAG0046.jpg]
Now take your masking tape and lay you logo on a flat surface and again put a line of tape over the logo on the left-hand edge, do this so the tape is right on the edge of the backing paper. And then the bottom right up to the edge. This will then be your guide line after the paper is removed.
[Image: IMAG0048.jpg]
Now fill the rest in with tape, and rub over the top to make sure its stuck to the tape.
[Image: IMAG0049.jpg]
Now flip it over and slowly peal the backing paper off be really slow with this as your logo is very thin in places.
[Image: IMAG0050.jpg]
Now get the top edge and line the to edges of tape together trying not to let the logo touch the surface you are putting it on. Line the tape up first and you know the logo will in the right place.
[Image: IMAG0051.jpg]
Now just rub over the top and make sure its really pressed on. Use the back of your finger nail to get in the little parts. And if you are fitting it outside at the mo, I would just give it a run over with a hairdryer before taking off the top tape. Then peal off the tape and you should have this.
[Image: IMAG0054.jpg]
[Image: IMAG0055.jpg]
And your done. So I hope this helps and please if you are still unsure please ring us, I would profer to speak to you and it gets fitted right then you can't do it.
Then after you have taken photos post them up so I can see them.
Good luck.
08-10-2019, 05:24 PM #1
Good luck.
Views 2,399
23-07-2019, 08:55 AM
