JapCarForum Car Manufacturers Mitsubishi Workshop - Submit your tips Nissan 350z Steering wheel removal
19-11-2019, 03:15 PM
Borrowed from elsewhere
Disclaimer.......this is just how I did mine, I accept no responsibility for airbags going off or lose of steering or any other situations arising from following the steps below.
Firstly, disconnect the battery & pump the brake pedal a few times to get rid of any surpless power that could be lurking in the system.
Next, remove the two clips, one each side of the steering wheel to expose the bolts. They have a tamper proof head but most mutli screw bit sets will have the right screw driver bit with a center hole in it to remove these.
[Image: SNV33425.jpg]
Once these two bolts are undone and removed, the center of the steering wheel (the airbag) will be loose. GENTLY pull this towards you and you will see a yellow connector at the bottom rear of the airbag which you need to unclip by pulling the middle black piece out. Once the actual airbag is removed, you will see the pic below.
[Image: SNV33424.jpg]
Next, I got a black marker pen and marked on the center thread and on the surrounding metal piece (attached to the steering wheel) I just made two small marks so that I could line up the wheel again when I came to refit it. You also now need to unclip the yellow cabled female crimp and the grey loom plug. Note how the cables are run to these items so you can reinstall them with the wiring the same way.
After that, I undid and removed the center retaining bolt.
[Image: SNV33423.jpg]
Once this is off, the wheel can be taken off...it might need a slight wiggle and a techincal tap from behind.
[Image: SNV33422.jpg]
[Image: SNV33419.jpg]
From here, it depends what you want to do with the wheel, either put it to one side if you are swapping it with a new one or the below shows how to strip it down for one reason or another.
Once the wheel is off, by placing it face down, you can remove the back plastic cowling by simply undoing the two screws (one each side) holding it on.
[Image: SNV33418.jpg]
If you want to remove the horn assembly then undo the single screw at the back (shown in red circles below) and the two larger bolts from the front (Be careful with these front bolts as they have springs below them to allow for the rebound action when you push the horn.
[Image: SNV334181.jpg]
[Image: SNV33417.jpg]
If you want to remove the front button surrounds then these will come off by simply undoing two more screws (again, one each side) once the rear plactic cowling has been removed. They are shown below just to the bottom left of center in the pic.
Once the two screws are undone, the front plastic trims will pull off.
[Image: SNV33392.jpg]
I took mine off to trim them in carbon
[Image: SNV33416.jpg]
Once you are done and want to put the wheel back together, it is basically retracing your steps and going back in the order you undid things in. Just make sure the wheel is tightly secured and you line up the two marks you made earlier on so the wheel is not crooked when aligned straight with the wheels. Also remember to plug the airbag cable back in, the yellow female crimp back in and the grey loom wire. There may be another loom wire for Z's with cruise control but I am only guessing at this.
Once all done, reconnect the battery and all should be good. If you are fitting an aftermarket wheel, you may need resistors etc but this How To is just for removing and refitting an oem wheel.
Hope this helps
19-11-2019, 03:15 PM #1
Hope this helps
Views 474
25-07-2023, 05:11 PM
Views 1,003
24-08-2022, 04:21 PM
Last Post by reganlives
Replies 84
Views 7,566
24-03-2022, 10:39 AM
Views 861
14-11-2019, 06:07 PM
Views 659
14-11-2019, 02:08 PM
Views 570
14-11-2019, 02:03 PM
Views 593
14-11-2019, 12:57 PM
Views 790
14-11-2019, 09:57 AM
Last Post by mplavery
Views 805
13-11-2019, 08:30 PM
