Not sure what to do?!
Need some help here with a very annoying problem
I have installed a aftermarket MOS headunit in my astra MK4, the connections was striaght forward ISO connections.
THe problem I have is when i turn the engine off and remove the key, the system loses everything, all settings, clock and cd position.
Why is this. my sisters got a MK4 and a aftermarket and it does the same thing.
So though Ill ask and fix both cars in one thread !
It sounds like you are lacking a permanent live connection, i.e. to keep the settings etc. When you turn the engine off you should still have a permanent live but clearly on yours you don't.
I presume there's some sort of issue with the connector/wiring/headunit.
excellent thats all i need to do? swap them round? red and yellow
Lexusboy And bang only joking mate....
Rabster should be yes its made this way due to some cars Ignition and live being the opposite way round
Why they cant keep things uniform i will never know
wicked ! nice one Rabster, worked perfectly did it in mine and then in my sisters !
now i dont have to keep tuning my radio
excellent news mate
Great stuff, well done !
